19-09-2004, 09:35 PM
Movie.Cam.Kvcd.Ds (AVG.Update) How to play????
How to view a movie
ie . Movie.Cam.Kvcd.Ds
(where Movie = ame of some movie)
Is there any speical viewer for viewing such movies , please help
I recently downloaded a movie with such extension, i dont know in which player should i play this movie
http://xforum.hugetop.com
Tutorials, Whitepapers, Beginner articles, How tos and Getting started Tutorials. All information you need about Computers, Ethical Hacking, Security, Web, Web Programming.
19-09-2004, 10:02 PM
try zoomplayer...btw u need right codecs also..so check that also
19-09-2004, 10:54 PM
error
I downloaded Zoom Player
It gives me a error
An Error has occured
__________________________________________________ _
Unable to play [Movie.Cam.kvcd.Ds.Bin]
This may be due to a corrupt file, missing filters,
filter conflicts, or hardware related issues
I havent installed any codecs, as i dont know which codecs i should install
Pls help
19-09-2004, 11:46 PM
ok i ll download this
ok dude i ll download this and try
its 19 mb, i ll keep it for downloading, and try it tm morning
hope it works
thanks for all ur help
20-09-2004, 12:36 AM
its a .BIN file
means its a cd image
therefore it'll be accompanied by a .CUE file of the same name
use this with software like clonecd/nero/alcohol 120% and write it on a cd ....
or u could try a virtual mount of the .cue with software like daemon tools/nero image drive/virtual cd emulator
or u could extract the contents of the image file using ultraISO
basically in the end the file will be a .MPG or a .AVI
No Mercy, No Limits.
20-09-2004, 07:33 AM
with k lite mega codec and classic media player u can straight play .bin files....
20-09-2004, 10:00 PM
its not .BIN file
when i downloaded the movie,
in its folder there are 3 files
1.) Movie.Cam.Kvd.Ds
2.) Movie.Cam.Kvd.Ds.cue
3.) Movie.ds
and i downloaded that k-lite. nope doesnt work on that even
21-09-2004, 12:55 AM
the file which is biggest...probably .ds....and play it in media player classic which comes with k lite...
21-09-2004, 06:15 PM
if it still doesnt just try what i suggested
21-09-2004, 10:07 PM
thanks dude for all ur help
thanks dude for all ur help , i ll try what all u have said
and keep u informed
Search this Thread |
