Old 11-08-2005, 09:48 PM   #1 (permalink)
mario_pant's Avatar
Default long lost computer performance......
hey... i used to have a bazing PC when i got it in 2002... it a compaq presario 1.6Ghz P4, 512SD ram.... 40GB.....winXP SP2.......
so i just wanna know how can i make my pc fast again.... it has reduced its performance by about 50%......
i've made a seperate partition for the paging file of 1 GB......... i defragment the disk every week..... i use PCtools Registry Mechanic......
anything else?
<-QUERY 2->
i recently installed SuSE 9.2...... now i wanna remove it..... and the stupid grub loader too.... how do i do this?
The name is Mario, "Mario Pant"!
mario = avatar; pant = पतलून
and i'm NOT some mountain KiD!
mario_pant is offline
Old 12-08-2005, 12:00 PM   #2 (permalink)
Wire muncher!
infra_red_dude's Avatar
well for paging file optimisation i suggest you take a look at this:
http://www.theeldergeek.com/paging_file.htm
also, do a repair installation from ur winxp sp2 cd to remove linux boot loader or if you are comfortable wid recovery console the, then get the rec. console up and running and type fixmbr.
also, enable dma and write caching in windows. make sure pci bus master is enabled in bios. remove any unused startup progs in windows.
infra_red_dude is offline
Old 13-08-2005, 02:05 PM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
Do this :
Go to mycomputer(rightclick)>manage>storage>local storage>Now delete the unknown identified partitions...
For boot loader...
If u got a WIN xp install disk then go boot into it and go to the repair console of the installation on ur primary drive and type FIXMBR.
If u dnt have one... DONT reboot directly after erasing lnx partitions...
Instead install osl 2000 boot manager and uninstalll it immeadiately...
Now reboot and Voila! no SUSE !
Harsh J
www.harshj.com
QwertyManiac is offline
Old 15-08-2005, 11:14 PM   #4 (permalink)
sidewinder's Avatar
Default Re: long lost computer performance......
anything else?
<-QUERY 2->
One thing for sure...u dont need that much page file...U shd hav 1.5 times the ram but its not applicable for pcs with 512 or more ram.So reduce ur page file manually to 512 mb coz si soft sandra sees this a s a problem..
Scan ur pc for spyware..virus nd dont run unnecessary progs in background.
The best thing is to reinstall ur os.U shd get optimum performance after that.Another thing..dont install un necessary programs..coz too much programs makes the os slow.
Another thing use a light on resource antivirus software such as avg,antivir and avast.
Bombina rocks
sidewinder is offline
Old 15-08-2005, 11:54 PM   #5 (permalink)
The Hardware Labs
mohit's Avatar
try o & o defrag v8 professional , let it defrag ur hdd (will take around 2-3 hours) ... there is a huge perfomance boost beleive me , i have used it myself. get it from here , (trial version)
http://www.oo-software.com/en/produc...efrag/pro.html
mohit is offline
Old 16-08-2005, 11:41 PM   #6 (permalink)
mario_pant's Avatar
um..... i think the problem was with the partitions.... i had 5 partitions from which two were of linus without any drive name...... i just deleted linux and just combined everything.... did a defrag.....virus scan.....deleted spyware..... uninstalled unnecesary s/w cleaned my startup... set the limits for page file.. and VOILLA decent performance boost.....
Old 17-08-2005, 01:32 PM   #7 (permalink)
In the matrix of linux
contactpraven2001's Avatar
One thing u can do that use spaywerw and antywires and remove unnesesry sofwere u instal in ur pc if after that there would be not much effect then the best opstion is that u can backup ur data and formet ue drive which have os and all the softwere and then reinslat it.
ofter reinstaletion instal only relevent softwere which u used comenly. put some spase in ur harddrive coz as load incress on hardrive there would be some loos of perfomence.
don't put lots of songs in ur deive if u want to store them the us cd and dvds i think it wil be better for ur pc.
Be original use pclinuxos ........
www.pclinuxos.com
contactpraven2001 is offline
- by Krow
