Old 11-08-2005, 02:13 PM   #1 (permalink)
Default help needed in buying a combo drive
hello guys
i need to buy a new combo drive nd don't tell me to go for dvd writer as im short on cash so plz tell me the best combo drive nd its prices i will be greatful if the prices r frm delhi
thnx in advance
shikhar
shikhar_kapoor143 is offline
Old 11-08-2005, 02:20 PM   #2 (permalink)
GaurishSharma.com
gary4gar's Avatar
u can get a combo drive of sony or liteon
as they are the best
it will cost u aruond
2300 bugs in nehru palace(approx)
a little bargain may give u a lower rate as well
gary4gar is offline
Old 11-08-2005, 04:24 PM   #3 (permalink)
MVP in VC++
I am having samsung Combo drive ....it is also good 1+ yr old no probs till date costs 2100/-
cvvikram is offline
Old 12-08-2005, 12:35 PM   #4 (permalink)
tuxfan's Avatar
Just a suggestion. Why not buy a separate CD-RW and DVD-ROM drives? Cost diff will be about Rs. 100-200. But you will get separate drives.
Here're the advantages IMHO
1. Copying CD to CD is faster with 2 drives
2. If one goes out of order and you send it for repairs, at least the other one is there.
3. If one goes kaput, you have to replace only that one. Cheaper. Isn't it?
4. Depreciates less becuase you use both and for a little extra sum you get 2 CD lenses, etc. Looks like better value for money to me.
tuxfan is offline
Old 12-08-2005, 01:03 PM   #5 (permalink)
Wire muncher!
infra_red_dude's Avatar
i second tuxfan, get a liteon cdrw and a sony dvd rw. the best combo!!! (of corz u can get a sony cdrw, but those are just rebadged liteons).
infra_red_dude is offline
Old 12-08-2005, 04:53 PM   #6 (permalink)
Just Do It
Charley's Avatar
Pls keep SAMSUNG out as its just has problems and more problems
Sony should be a good option
Charley is offline
Old 12-08-2005, 07:40 PM   #7 (permalink)
Wire muncher!
yeah samsung is plauged wid the infamous "tray" problem! and lotsa other problems...
Old 13-08-2005, 01:45 AM   #8 (permalink)
tuxfan's Avatar
Here's the hat trick of opinions against Samsung. Stay away from it. Buy Sony.
tuxfan is offline
- by Krow
