Old 11-08-2005, 03:10 AM   #1 (permalink)
siriusb's Avatar
Default Https funda
Hey,
I would appreciate if u help me out.
How https works (apart from it's rfc and its definition of http+ssl) and how resume of downloads is supported in https, if that is possible? Does it use the "Range:" header as http1.1 too?
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 11-08-2005, 04:07 PM   #2 (permalink)
You can read this page. http://www.dunelm.org.uk/help/secure.php3
Though not much in it,atleast a basic idea of how it works.
www.Oobertech.net
digen is offline
Old 11-08-2005, 08:08 PM   #3 (permalink)
siriusb's Avatar
Ok, let me refine my question more.
I read that "MAC-info" header is used to provide message authentication to the client. This calculation involves the message bits and other things.
If anyone has worked with security and crypto, then can you tell me if the message bits considered for this mac calculation be according to the range of bytes specified by the client in the "range:" header? Or am i wrong fundamentally somewhere?
Any resourse pointed out would be great.
siriusb is offline
Old 13-08-2005, 10:24 AM   #4 (permalink)
siriusb's Avatar
Please, atleast tell me the any other forums where i can post. If pointing to another forum is not permitted by this forum, then atleaset pm me.
siriusb is offline
Old 13-08-2005, 11:44 AM   #5 (permalink)
QA Juggler
saROMan's Avatar
Herz a Extract From Sun.....How HTTPS works with Java ....Sory came up with this only ....will try to get more....also see this for more info about SSL
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 13-08-2005, 08:40 PM   #6 (permalink)
siriusb's Avatar
Thanks for those links, saroman. I guess it would be better to get it answered by a person than a document (as I aven't found one in google).
siriusb is offline
- by Krow
