10-08-2005, 09:17 PM
can any body help me ?
Hi friends i have a prob' with my pc. i have p3 pc with 20 GB harddisk i have made it into 3 parts using partion magic ie: 10GB,9GB,1GB but now the prob' is the 1 Gb space is not showing and i have tried to format it but its not formating.can anybody help me?
with regards...
subhu.
10-08-2005, 09:32 PM
Wire muncher!
can u elaborate ur problem a bit more? i mean, is the 1 GB partition not showing visible or wot? how can u try to format it when the partition itself is not visible? plz give more details.
10-08-2005, 09:44 PM
yah sure
the prob' is it can't be seen when ur system is up means it can't be used, but partition magic shows it and while new installation of OS it shows ,but if u try to format it ,it won't. what may the prob'?
10-08-2005, 10:01 PM
Wire muncher!
What OS do u use? and what type did u create the partition as (fat, ntfs etc.)??
10-08-2005, 10:03 PM
Rebooting
@subhu
1. what is the file system??
2. is the 1GB parttion Primary DOS drive or logical one??
3.which OS u r useing??
now if u have the system page file in that partition system wont b able to format..
4. So where is ur page file?
now the AVS auto protection is enabled then AVS might not allow u to format
5. So have u tried after dibleing the Real-time protection??
6. How r u trying to format?? after booting from HDD or from CD/Floppy boot??
lol.. may b too many question... but u know this r the common foults... do reply...
rebooting
ChotoCheeta.com
10-08-2005, 10:05 PM
xp
i use win xp prof' anf th epartition is Fat32.
10-08-2005, 10:11 PM
hi sourav
yah saurav ! i tried several methods but its not working i don't know y? even full system format also leave this 1 GB space .can u find any solution for this ?
thanks
10-08-2005, 10:16 PM
was the 1gb partiton created last???
Manav Mohanty
Uniservze
Calcutta
10-08-2005, 10:18 PM
yah manav the partition 1 GB was created last.
10-08-2005, 10:22 PM
Since you have Partition Magic, use the "Merge Partition" option to club 9 and 1 gb together.
Keith
10-08-2005, 10:26 PM
keith... no merge ..no delete... no format ..nothing is happing...it just shows the space in 'PM' and while formatting but u can't do anything,
10-08-2005, 10:35 PM
No saurav after full deletion it will show 19Gb + 1Gb saparetly.
10-08-2005, 10:51 PM
Microsoft MVP
Try to boot using Windows XP bootable CD and when it asks the location to install windows (i.e. shows the partition table to select partition) , select the 1 GB partition that u want to format and delete it.
It can also be done using Red Hat Linux or FC CDs. It also allows us to remove, format partitions.
10-08-2005, 10:56 PM
hello vishal i'm telling that i can't delete r do nothing while formatting also.
10-08-2005, 11:11 PM
Microsoft MVP
Do u hv 20 GB HDD?
No HDD gives u exact space as its size.
If u r getting 19 GB from a 20 GB HDD, then its fine.
U can't do nething...
17-08-2005, 10:44 PM
hello
hello 20GB means 20 Gb there will be no exsemtion okay , no company will do like that, i had worked on that full 20 Gb and know after doing partion i can't.
Search this Thread |
