Old 10-08-2005, 07:31 PM   #1 (permalink)
Default Need a graphic card
hey,
just tell me a graphics card.i mostly work in Combustion, Maya,photoshop, After Effects,flash,3d sudiomax and im not a gamer so take this into consideration.my budget is only 7500Rs.if u suggest any driver tweaking just tell me which graphics card with in this range (7500)can be tweaked.
vraja4u is offline
Old 10-08-2005, 09:04 PM   #2 (permalink)
siriusb's Avatar
This is the same question that was being discussed for u in thread just below this one. Why did u break it off to here?
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 10-08-2005, 10:36 PM   #3 (permalink)
hey no one has replied to it so i posted a new one .so please suggest me a good graphics card......
vraja4u is offline
Old 11-08-2005, 12:05 AM   #4 (permalink)
just cos no one replies does not mean u start a new thread. And did you not see the sticky which says all graphic card related queries. Then why here ? Sorry mate rules are rules. Thread reported.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
- by Krow
