View Poll Results: which is the best game of the following
a) gta sa 3 60.00%
b) prince of percia 2 40.00%
Voters: 5. You may not vote on this poll
Old 10-08-2005, 02:03 PM   #1 (permalink)
GaurishSharma.com
gary4gar's Avatar
Default hang man
My configuration is as follows:-
· Amd anthlon 3000+
· MSI K8MM-V
· 256 MB RAM hinux(shared)192mb normal and 64mb vedio
· 80 GB SATA segrate
· sony combo drive
· no graphics card is installed
when i play gta III system hangs often once or twice in 2,3 days
a recently update bios and graphics driver
Can anyone one help!!!!!!!!!!
gary4gar is offline
Old 10-08-2005, 04:43 PM   #2 (permalink)
expertno.1's Avatar
hey man ur topic for this is not suitable
upgrade your system or get more fans coz hanging is due to overheating
use speedfan to measure the temp
and change the topic
gta sa is best
expertno.1 is offline
Old 10-08-2005, 05:28 PM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
YEP i guess its heatin problem..
Also, plz post this in some section like gamerz,
Also, POP 1 or 2 ?
POP1 is bttr
Harsh J
www.harshj.com
QwertyManiac is offline
Old 10-08-2005, 05:48 PM   #4 (permalink)
Rebooting
Choto Cheeta's Avatar
hmm currently i am on ASUS A7V8X MX SE.... mobo.. which has the VIA chipset as the MSI K8MM-V board.... i have 512 MB of DDR400 & Athlon 2600 XP... so will my system b able to run GTA SA in minimum/lowest setings??
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 11-08-2005, 02:01 PM   #5 (permalink)
GaurishSharma.com
gary4gar's Avatar
but sonn after hang i entered my bios
and check the temp it says
cpu temp-----49
system temp-------42
is it overheating
i have a Athlon 64 3000+
a extra fan is installed
gary4gar is offline
Old 11-08-2005, 02:16 PM   #6 (permalink)
siriusb's Avatar
Nope, it's not. 60deg maybe something to worry. But system temp is a bit high. If ur mobo has a chipset fan, then check to see if it's working.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 11-08-2005, 10:26 PM   #7 (permalink)
Rebooting
hmm for BOX FAN... might wana take @ this post
help: - Installing Cabinet FAN....
rebooting
ChotoCheeta.com
Old 16-08-2005, 12:33 PM   #8 (permalink)
GaurishSharma.com
gary4gar's Avatar
i have already installed is fan
inthe cabinet
gary4gar is offline
- by Krow
