Old 10-08-2005, 01:56 PM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Hdd Defrag ! ! !
which tool do u prefer for defragging hdd ??? (default - windows 1 or any other)
which 1`s the best ??? wanna use 1 ...
ax3 is offline
Old 10-08-2005, 02:34 PM   #2 (permalink)
alib_i's Avatar
System Mechanic
alibi
-Metallica
alib_i is offline
Old 10-08-2005, 03:51 PM   #3 (permalink)
royal's Avatar
Use O&O Defrag
http://www.oo-software.com/en/
royal is offline
Old 10-08-2005, 03:57 PM   #4 (permalink)
rajat22's Avatar
The fastest defrag I ever seen. In a dual boot system with 98 & XP.
Defrag with Norton System Works speed disk from 98.
Simply fantastic. Nothing can beat it. Telling you after testing all other.
I simlpy cannot remove 98 from my system ONLY TO DEFRAG WITH NORTON SPEED DISK.
____________________________________________
A person who never made a mistake never tried anything new.
rajat22 is offline
Old 10-08-2005, 04:05 PM   #5 (permalink)
MVP in VC++
How is O&O Defrag ???
Is it good and fast....
cvvikram is offline
Old 10-08-2005, 04:25 PM   #6 (permalink)
expertno.1's Avatar
o&o is fast but not faster than the system mechanic walla
one more i use is windows xp defragmenter (slow)
and one Diskeeper Pro Edition..the best one i defrag !!!!!
expertno.1 is offline
Old 10-08-2005, 06:00 PM   #7 (permalink)
royal's Avatar
If ur talking about raw speed Norton Sys Works is better than O&O Defrag but the former is a real resource hogger
Also I dont know whether Norton supports background defrag which O&O does
royal is offline
Old 10-08-2005, 06:01 PM   #8 (permalink)
Rebooting
Choto Cheeta's Avatar
well i use NTFS file system... the windows defrag does the job for me.... its really really fast... faster than any other 3rd party tools... but again u have to keep in mind the NTFS factor....
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 10-08-2005, 06:56 PM   #9 (permalink)
Let the music play.....
djmykey's Avatar
I use perfect disk 7
djmykey is offline
Old 10-08-2005, 07:32 PM   #10 (permalink)
Can you tell me more about defrag? When defrag i do not note any difference in my system. Is it really helpful?
shivaranjan.b is offline
Old 10-08-2005, 08:04 PM   #11 (permalink)
Rebooting
@shivaranjan.b
1. what is Defragmentetion??
2. Why should one defrag his HDD??
3. How doesthe defragment (Microsoft Windows) works??
4. What Is (Microsoft Windows) Disk Defragmenter??
rebooting
ChotoCheeta.com
Old 10-08-2005, 08:28 PM   #12 (permalink)
That was really a great piece of information. Good work. One more question. How often to do that? If i do defrag every week won't i be straining my hdd as it has to write lot of data because i have a 160gb and 120gb hdd.
Old 10-08-2005, 08:33 PM   #13 (permalink)
mariner's Avatar
i too have a dual boot with 98 and xp and norton speed disk and sys mech have all failed to go after a certain point. so its back to windows defragmentor and works good man.
mariner is offline
Old 10-08-2005, 09:11 PM   #14 (permalink)
Wire muncher!
infra_red_dude's Avatar
well defrag at least once in a month or after you've installed something heavy on ur hard disk. you may also need to defrag when any program installs a lot of small sized files.
infra_red_dude is offline
Old 10-08-2005, 09:18 PM   #15 (permalink)
My opinion is that Diskeeper is good enough
raasm287 is offline
Old 10-08-2005, 09:18 PM   #16 (permalink)
siriusb's Avatar
Basically, if u defrag after deleting a few dozen small files or one or two large files, you can be sure to have contiguous space for future installations.
Even if u were only using existing programs but not installed anything, defrag once every month or once your usage pattern/frequency of certain app changes. This will move the most frequently used progs to the front of the hdd for faster loading.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 10-08-2005, 09:29 PM   #17 (permalink)
Rebooting
it depends on u... as for normal use... i personaly would say once in a week would be better option... & yes if u r in FAT32 then no matter what tool u use it gone take long time... much time in ur 160GB as well as 120GB... so better to switch to NTFS (if posseble...).... NTFS is way better/faster/more secure than FAT32.....
Beware OS before win2000 wont b able to view NTFS.... so if u r in winXP or 2k.... go for NTFS...
rebooting
ChotoCheeta.com
Old 12-08-2005, 11:34 AM   #18 (permalink)
ax3
ax3's Avatar
bt defraging again & again ... won`t hdd get scraches or b more damaged ???
their has 2 b some time interval na ! ! !
... W H O T ...
ax3 is offline
Old 12-08-2005, 11:38 AM   #19 (permalink)
ax3
ax3's Avatar
i have win xp ...
will defraging from dos mode b fast ...
as many of window components will b off ... as they interfear lot when the process is on ...
... W H O T ...
ax3 is offline
- by Krow
