Old 09-08-2005, 10:41 PM   #1 (permalink)
mario_pant's Avatar
Default wut the hel is up with these ports??
ok....
i just got myself a connect "hi-speed" connection...... i thing i'm on a LAN or something connected to my network card..... the problem is that emule and bittorent do not work..... skype and warez p2p work absolutely fine..... i tried to use the same ports as skype does but NO it wont budge..... it is just the same.....i called the people... they told me that i shud use port 80 i did it but nothing....... can someone help?
The name is Mario, "Mario Pant"!
mario = avatar; pant = पतलून
and i'm NOT some mountain KiD!
mario_pant is offline
Old 10-08-2005, 12:06 AM   #2 (permalink)
can u give us a lil more info on which broadband solution ur using ? That will give us a bit clearer picture as to what the problem might be. Also if it is BSNL or Airtel or hatway or Sify those problems have already been mentioned here a lot of times and people have had their ports opened. So I would suggest doing a lil searchin b4 jumpin the gun mate.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 10-08-2005, 01:53 AM   #3 (permalink)
alib_i's Avatar
go to http://www.grc.com/stevegibson.htm#projects
and scroll down to ShieldUP!. Click on it to check your ISPs open ports
alibi
-Metallica
alib_i is offline
Old 10-08-2005, 07:54 PM   #4 (permalink)
mario_pant's Avatar
i use connect hi-speed 94kbps...... unlimited....
Old 11-08-2005, 09:29 PM   #5 (permalink)
Commander in Chief
QwertyManiac's Avatar
huh ?
Never heard of that
well, try the tool mentioned...
Harsh J
www.harshj.com
QwertyManiac is offline
- by Krow
