Originally Posted by raghu-RAM
i use p4 3.00 GHz processor with HT technology
I think you are using Pentium 4 with EM64T (not Xeon with EM64T/Itanium). Otherwise it is 32bit.
So, it is a x64 processor. The biggest difference between x64 and other 64-bit processors is that x64 processors are compatible at the hardware level with 32-bit, x86 processors. There are currently two basic x64 processor families:
• AMD's amd64
• Intel's EM64T
From
AMD, this includes the
Athlon 64,
Athlon 64 FX,
Mobile Athlon 64,
Turion 64, and
Opteron processors. From
Intel, this includes the
Xeon with EM64T and
Pentium 4 with EM64T processors. The two architectures are binary compatible, allowing Windows XP Professional x64 Edition to use a single version to support both.
So, you can run any version of Windows including WindowsXP x64. Even you can use both XP and XP x64 dual booting.
