Hi guys , plz see this code for me
The problem lies in the Inserting of node portion.
#include<iostream.h>
#include<conio.h>
#include<stdlib.h>
#include<stdio.h>
struct linklist
{ int data;
linklist *next;
typedef struct linklist node;
void create(node *start);
void insert(node *start);
void display(node *start);
void inter(node *start);
void main()
{clrscr();
node *start;
int ch=0;
while(ch!=5)
cout<<"\n\n 1 . Create the linklist ";
cout<<"\n 2 . INsert in Link List";
cout<<"\n 3 . Display ";
cout<<"\n 4 . Interchange two nodes";
cout<<"\n 5 . Exit ";
cout<<"\n\n our Choice (1-5)";
cin>>ch;
switch(ch)
case 1:
create(start);
break;
case 2:
insert(start);
break;
case 3:
display(start);
break;
case 4:
inter(start);
break;
case 5:
exit(0);
break;
default:
cout<<"\n Enter valid choice";
break;
getch();
//start = new node;
int val=0;
while(val != -1)
cout<<"\n Enter the data to insert ( -1 to quit )";
cin>>val;
if(val == -1)
break;
start->data=val;
start->next=new node;
start=start->next;
start->next=NULL;
void insert ( node *start )
{ node *temp;
int val,pos;
temp=new node;
cout<<"\n Enter the Data you want to Insert \t";
cin>>val;
cout<<"\n Enter the position where you want to insert (0 to insert in the beginning \t";
cin>>pos;
if (pos==0)
{ temp->data=val;
temp->next=start;
start=temp;
else
for(int i=1;i<pos;i++)
{ start=start->next;
if(start->next==NULL)
{cout<<" INcorrect position ";
break;
temp->data=val;
temp->next=start->next;
start->next=temp;
void display ( node *start )
{ cout<<"\n The elements are \n";
while( start->next != NULL)
{cout<<"\t"<<start->data;
start=start->next;
{ node *p,*q;
p=q=start;
int a,b,i,temp;
cout<<"\n Enter the position you want to interchange \n";
cin>>a;
cin>>b;
for(i=1;i<a;i++)
p=p->next;
for(i=1;i<b;i++)
q=q->next;
temp=p->data;
p->data=q->data;
q->data=temp;
The programs runs fine but i am unable to add a node to the beginning although the logic i have used is correct . Kindly help please
