Old 07-08-2005, 03:51 PM   #1 (permalink)
Default Help Required in Bit Torrent-Incorrect Peer Info
Hello
I started downloading a 825 MB .avi file through Bit Torrent using Bit Spirit.I reached till 210 MB but then i had to turn off the computer.After i started the computer again by mistake i used Bit Comet to download the.It recognized the previously downloaded 210 MB of it but it didnt download any further.Then i realised my mistake and switched over to Bit Spirit.Even Bit Spirit recognized the 210 MB downloaded already.But then it connects to the tracker,authenticates but then i get the messages:
Building Peer Info
Incorrect Peer Info!
in the log
The "Incorrect Peer Info!" is marked with a red cross.
My all other torrents are working fine except this one.
Can anyone please help?
If neccessary i will send you the torrent file.
Thanking you in anticipation of a favourable reply
rachitar is offline
Old 07-08-2005, 06:46 PM   #2 (permalink)
Another Brick in the Wall
drgrudge's Avatar
Hmm, it's not a mistake, it should be able to download in *ANY TORRENT CLIENT* not the client that you have used b4 to download.
So what if it shows error or some stuffs, the torrent file is running fine naa?
drgrudge is offline
Old 07-08-2005, 08:13 PM   #3 (permalink)
Sadly no
rachitar is offline
- by Krow
