Old 07-08-2005, 11:10 AM   #1 (permalink)
mekalodu
iinfi's Avatar
Default streaming LIVE AUDIO ... HELP
whenever i stream live audio frm BBC or any other website of football matches the audio volume is very low .... i have strain my ears to hear the commentry.
on all other occations the volume is fine. mine is a 56-80Kbps connection.
if the streaming is not of LIVE content the audio is audible.
whats the problem i m facing? i have kept the volume of all the players in my system to the max. and the system volume and speaker volume is also max.
mekalodu
iinfi is offline
Old 07-08-2005, 11:30 AM   #2 (permalink)
expertno.1's Avatar
u should use players which has accelerated auido playing like jet audio which matches the 0 db sound to get you the volume boost no matter how much the sound quality is low
expertno.1 is offline
- by Krow
