Old 18-09-2004, 07:08 PM   #1 (permalink)
Default Making an FTP Server and remote accessing
Hi!
I use Bulletproof Ftp server and a hathway internet connection (LAN connection internet).
I created a ftp server but my friends who use other isp for net connection cannot connect to my server.
When i checked my ip address through bulletproof ftp server it showed my ip and some remote ip address which is different from my ip address.
Can anyone help me setup my ftp server.
Also how do i remote access a computer in KOLKATA sitting here in MUMBAI. The system in KOLKATA runs Windows 2000 server and the system in MUMBAI uses Windows XP. Which services shouold be started in the KOLKATA system and which software should be used in MUMBAI system.
Please help me with my problems. I will be very greatful to the one who helps me.
troubleshooter is offline
Old 18-09-2004, 09:14 PM   #2 (permalink)
for the ftp prob, i remember long time ago dere was a big article in digit on setting up ftp servers, so look in dere archives or sumthing it mite help you out....i think its a prob of having a dynamic ip wen u need a static one....this can be done i dont remember how
for accessing ur pc, i used one called GoToMyPC sum time back.... its at www.gotomypc.com but now dere r many more softwares available for this, search for them on google....i think gotomypc is a demo or sumthing....time limited then u g2 pay l8r
ishaan is offline
Old 18-09-2004, 11:44 PM   #3 (permalink)
tell me your ip (only the first three octate) see is it a private ip and maybe hatway uses nat or somthing for letting you on to the internet.
**** happens
pradeep_chauhan is offline
Old 19-09-2004, 12:56 AM   #4 (permalink)
aadipa's Avatar
try useing No-IP
it is used for getting URL bound to dynamic IP but i donno whether it work under NAT.
Just give it a try
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 19-09-2004, 04:16 PM   #5 (permalink)
I have a static IP its 192.168.166.xxx. its a shared connection provided by hathway. The remote IP is 202.88.xxx.xxx. My friends on the lan connection can connect to my FTP server but not anyone else on other net connection. I think u need some ip routing enabled maybe.
Old 19-09-2004, 04:23 PM   #6 (permalink)
your isp has to provide port forwarding to allow connection from a server outside their network.
Victory breeds hatred, for the defeated live in pain. Happily live the peaceful, giving up victory and defeat.
oldmonk is offline
Old 19-09-2004, 04:27 PM   #7 (permalink)
How do tell my isp to do ip forwarding
Old 19-09-2004, 06:53 PM   #8 (permalink)
ask them
they might do it for you
oldmonk is offline
Old 21-09-2004, 05:27 PM   #9 (permalink)
Your ip is private IP. Since 192.x.x.x is reserved for private. Most probably you r behind a firewall. And 202.88.x.x is a public ip.
You can use Remote Anything. They have a feature, Directory Server, whcih useful to control the pc behind firewall.
Directory Server should be install on Gateway to do NAT between private IP and Public IP. Download is also small, around 300KB. But trial version is only for 5 mins and only one pc can be connected at a time.
Think of me n I will be there
amistik is offline
Old 21-09-2004, 07:09 PM   #10 (permalink)
Walking, since 2004.
mail2and's Avatar
well on hathway u can't host anything as we are on private ip.. i had asked the guys to pen a port for me.. but they didn't do it.. so basically on hatwhay u can't access sites unless u r on the same lan...
Mumbai, I miss you. :(
mail2and is offline
- by Krow
