when the message says -- Nero's Burning Engine is used by some other application.
then press CTRL + ALT + DEL to launch Windows Task Manager and click on "Processes"
there you will see the IMAPI service running. select it and click on "End Process".
by the way, the Nero 5.5.9.9 is an old version, I had that last year.
Install Nero 6.3 and check again if the problem persists.
