06-08-2005, 04:54 PM
Commander in Chief
Problem with CD-Recorder (samsung) URGENT !!!!!????
Problem with CD-Recorder (samsung):
When I try to burn a disc, the CD - Buffer level keeps jumping from 19-97%
(exaclink activated) and somehow after the burning process shows complete, there is no data on the CD, Its VERY Urgent for me to burn some FC4 cds
PLz HELP !
Thanks for ur Opinions in advance and I ' ll thank u again...
PLEASE HELP QUICKLY
Harsh J
www.harshj.com
06-08-2005, 05:07 PM
Commander in Chief
K , Opinions will do too,
Any opinion, anything, but fast and quick, i need it URGENT
Harsh J
www.harshj.com
07-08-2005, 12:59 AM
Dead drive?
My sony did it to me and that was the result...
07-08-2005, 02:42 PM
Commander in Chief
No the drive writes it sometimes but it fails mostly,
The buffer memory keeps changing....
If i minimize the window, the CD gets magically written but its a problem for me anyway...
Harsh J
www.harshj.com
07-08-2005, 05:09 PM
Commander in Chief
plz hlp somebody...
Harsh J
www.harshj.com
07-08-2005, 06:50 PM
you are saying if you minimize then the cd gets written, then try in other cd writing softwares.
07-08-2005, 07:11 PM
Commander in Chief
yes but it takes 6 min instead of 2 min at 52x and still the buffer jumps...
Harsh J
www.harshj.com
07-08-2005, 08:33 PM
try writing the cds at slower speeds
like 40X or less.
if that does not help then check that the led that blinks during writing is blinking ( maybe by mistake u r writing into an image file)
then get back to me again
Aviation (Aircraft Maintenance Engineering)
http://www.ame-world.frih.net
07-08-2005, 08:41 PM
1. write at slower speeds
2. shutdown any background programs that use HDD or a lot of ram
3. increaase the amt of ram used as buffer
4. change the location of temp folder of nero to a partition which is not a system partition
try these and get back with the results
07-08-2005, 08:47 PM
by the way budy if u have samsung SW-252F then plz get it repaired or write it at no more then 16x
coz;
i have that stupi* *** writer and it is doing exactly what u says at high speed[samsung sucks big time]
09-08-2005, 09:44 PM
Commander in Chief
yep i have it..
Harsh J
www.harshj.com
11-08-2005, 05:40 PM
Commander in Chief
Hullo !
Yep , i tried wat u said bout ram and all that but i can now burn succeessfully at 16x only, man what did i buy a 52x for ?
Harsh J
www.harshj.com
12-08-2005, 08:19 PM
Commander in Chief
Hullooooo ?
Any more suggestions ,
Plz
THNX in past for the future...
Harsh J
www.harshj.com
13-08-2005, 10:19 PM
try defragmenting ur HDD
and one more thing try cleaning ur registry regularly with regcleaner
15-08-2005, 06:13 PM
Commander in Chief
Hoows that gonna help my hardware buffer....?
Plz elaobrate..
Harsh J
www.harshj.com
17-08-2005, 07:52 PM
thats not gonna help ur hardware buffer in any way but you may get a boost in performance and the rate of data transfer to ur cd drive from hdd will increase.
19-08-2005, 12:03 PM
Commander in Chief
Hey i got a sata hdd with 100mbps write and transfer rate, tis a hrdwre prob i guess, can u point me to a samsung repair shop in chennai ?
Harsh J
www.harshj.com
20-08-2005, 05:22 PM
#19 (permalink)
Commander in Chief
Thnx, i m sendin my drive , bye bye...
Harsh J
www.harshj.com
Search this Thread |
