Old 06-08-2005, 04:02 PM   #1 (permalink)
Default How to change memory bus mode?
I'm currently running at 64-bit memory bus mode instead of 128-bit memory bus mode (which my DIMMs support) so how can I make that change?
Mahesh Babu is offline
Old 06-08-2005, 04:42 PM   #2 (permalink)
siriusb's Avatar
What u need are two memory sticks in the right slot to make dual channel (128) work. Refer to ur mother board manual to see what memory are supported and which banks to insert them into.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
- by Krow
