Old 18-09-2004, 07:05 PM   #1 (permalink)
QA Juggler
saROMan's Avatar
Default Anonimus Surfing
I have resently braught a new net connection at home ..........
& have been hearing lot about hacking in to the system while u r chatting etc.......though i use zone alarm pro as my firewall ...but still i want to know if there is any way / software thru which my IP add will be safe from prying eyes ......i have heard that anonimyzer.com is one such site...but its too confusing for me.........can any one help???
saROMan is offline
Old 18-09-2004, 07:07 PM   #2 (permalink)
Just relax Zone alarm takes care of hiding your IP. There are many online security checking sites check your settings online. I dont think anything else is required.
**** happens
pradeep_chauhan is offline
Old 18-09-2004, 09:28 PM   #3 (permalink)
pradeep is right unless the pc ur talkin about has some real imprtant info that biznez rivals will die 2 get or national security info about the schedules of the pm which the terrorists will wanna get....in that case....da best advice will be to put away dat modem...lay down u r fone linz...n neva connect dat pc to the internet
ishaan is offline
Old 19-09-2004, 02:41 AM   #4 (permalink)
ya i m sure that it's not that imp for a home user to check for spy(Just look for the parents)
nd Zona alerm is good it can take care of all ur need
Music is like Sex, The more you get, the more you want.
demoninside is offline
Old 19-09-2004, 08:15 AM   #5 (permalink)
The Photoshop Guy
cooljeba's Avatar
Default Re: Anonimus Surfing
m8 it depends on the connection. If you have a dialup u need not worry 'casue the IP changes everytime you connect to the net. If you have a cable internet they you get a static IP.
BTW Zonealaram will take care of your privacy . Just make sure that you don't take attachemnts from unknow source and do scan the attachements from the know source too 'cause they can send some trojan unkowingly .
..:: peace ::..
Jeba
cooljeba is offline
Old 19-09-2004, 06:33 PM   #6 (permalink)
ZoneAlarm will take care of it.
Simple things are to simple too understand.
Prashray is offline
Old 21-09-2004, 01:27 PM   #7 (permalink)
mariner's Avatar
well u need a good firewall and u have zone alarm for it.do as jeba says, dont opn any unknown attachments.
ur worry should not be that ur pc might be hacked.u should worry that ur pc might be used by hackers/crackers to hack into some other site or pc.
mariner is offline
Old 22-09-2004, 01:46 AM   #8 (permalink)
#/bin/sh's Avatar
use firewalls.
\"99 little bugs in the code, 99 bugs in the code, fix one bug, compile it again, 148 little bugs in the code. 148 little bugs in the code....\"
#/bin/sh is offline
- by Krow
