Old 06-08-2005, 09:03 AM   #1 (permalink)
Default real puzzling problem about HDD space disappearing
I have sent a post earlier also about this . Whats happens is that regardless of what I delete I do not get back the space occupied by these files , its not there in the recycle bin , or some temp directory or any other directory, I do not have norton protected recycle bin, even the disk space wizard does not free up the space occupied by these files , it does free up some space from temp , intenet temp dir etc... but not the space occupied by the files which I delete !! My HDD space is continuously going down now jusT 1GB , I've never seen this before , HELP !
Huzefa is offline
Old 06-08-2005, 10:54 AM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Simple, Jus close ur System restore (my comp's properties)
and watch the space bloat 'gain...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 07-08-2005, 02:53 PM   #3 (permalink)
GetUserTitle()
huzaifa b arab's Avatar
which Os r u using my 'HUMSHAKAL'
*Thinks of a witty one-liner...still thinking*
huzaifa b arab is offline
Old 07-08-2005, 10:04 PM   #4 (permalink)
q3_abhi's Avatar
In WinXP, system Restore should be turned off as said by qwertymaniac. Delete everything in
x:>Windows>Temp>... Use a program like "Find Junk Files". It will help u.
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 08-08-2005, 12:18 AM   #5 (permalink)
hafees's Avatar
yes, it is because of the System Restore program. This program will reserve some space for storing informations necessary for the program to work.
You can check how much space is reserved by Right clicking on My COmputer, Properties and then by clicking the System Restore tab. Then you can select a drive and verify howmuch percentage of space is reserved. (typically 10-20%). You can either turnoff system restore for a selected drive or for all the drives.
You can either decrease the reserved space or turn off system restore completely.
hafees is offline
- by Krow
