Old 05-08-2005, 11:44 PM   #1 (permalink)
Pharmaguru
kjuvale's Avatar
Default repair bad sectors
hi is there any way to repair bad sectors of hdd
please help.
My Photography gadgets :
Nikon D5100 with 18-55mm VR Lens, Nikkor AF-S 50mm 1.8g, Tamron VS 70-300 VC Di
Cullmann NANOMAX 220 Tripod. | Crumpler messenger boy stripes 4000 camera bag :grin:
kjuvale is offline
Old 05-08-2005, 11:51 PM   #2 (permalink)
siriusb's Avatar
Your best bet is to do a
"chkdsk /f"
if u have xp and hope the bad sectors go away. For win98, do a scandisk with thorough option and "fix errors" option checked. Or u can go to your hard disk manufacturer's website and download a so-called 'low level formatting utility". It tries to remap the bad sectors to spare sectors on your hdd so that u won't be bothered by them any more.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 05-08-2005, 11:59 PM   #3 (permalink)
Wire muncher!
infra_red_dude's Avatar
there is no way to recover physical bad sectors. at most wot can be done is, as siriusb said, they can be remapped if there are spare sectors.
however try the scandisk thingy in the end after trying every other software, coz once scandisk marks certain sectors as bad nothing can be done without a lowlevel format. the markings are pretty strong and once marked you can be sure that no data will be written to those "marked" sectors.
infra_red_dude is online now
Old 06-08-2005, 12:04 PM   #4 (permalink)
ramprasad's Avatar
Hi,
There is no way (atleast as far as I know) to recover the data in bad sectors. But u can patch them and prevent the OS from writing/using it again.
Try Seatools from Seagate.
Visit ur HDD manufacturer's website for getting the right S/W to patch it up..
I have used Seatools, it even worked perfect into a linux partition..
Regards,
Ramprasad
ramprasad is offline
Old 06-08-2005, 02:13 PM   #5 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Lemme tell u my experience...
When u have bad sectors... better Scandisk throughly(of course u might have done it already... then come to the conclusion of bad sectors
Then full format the drive... This makes the system omit the bad sectors and think them to be 'not present'.
Thus, ur drive'll look free of bad sectors... most of these bad sectors'll be omitted...
koolbluez is offline
Old 06-08-2005, 03:42 PM   #6 (permalink)
expertno.1's Avatar
1)scandisk
2)chkdsk
3)windows defragmenter
4) peek time pro
expertno.1 is offline
Old 06-08-2005, 09:27 PM   #7 (permalink)
q3_abhi's Avatar
Yes, most of these softwares make those Bad sectors to skip or either use a spare sector(i don bout spare sector). Use may use a utility called DM- Disk Manager. These software is available for samsung,seagate,quantum.
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 06-08-2005, 09:58 PM   #8 (permalink)
Use HDD Regenerator
http://store6.esellerate.net/store/P...9923428806&pc=
cooltarun is offline
Old 06-08-2005, 10:31 PM   #9 (permalink)
rajat22's Avatar
cooltarun is right. I have recovered 575 kb of bad sector with it.
All software created bad sectors are recoverable.
Dont try to recover physical bad sector.
____________________________________________
A person who never made a mistake never tried anything new.
rajat22 is offline
Old 06-08-2005, 10:44 PM   #10 (permalink)
siriusb's Avatar
I suggest that you read the entire hard disk reference in this page:
http://www.storagereview.com/guide2000/ref/hdd/
For info abput spare sectors and stuff, sjip over to here:
http://www.storagereview.com/guide20...matDefect.html
siriusb is offline
- by Krow
