hey mates , plz help me finalize my tv-tuner purchase . i am looking for the best product available and so decided to go for pinnacle but i have ended up getting confused with so many different models available. my requirements are as follows ,
it should be an
EXTERNAL TV-TUNER with REMOTE.
Best possible audio/video quality ( i wanna know if ill be getting surround sound as i am using 4.1 speakers )
Budget is max . 3000/-
It should be able to capture video from external sources such as a vcr or camcorder. (i have lots of old vhs tapes that i need to convert to dvd's)
It should be fully compatible with my cable connection (typical indian type) and support atleast 100+ channels.
It should allow me to pause my shows (i.e record my fav programmes on my hard disk for viewing them later)
the pinnacle range can be seen here,
http://www.pinnaclesys.com/PublicSit...er_tvtuner.htm
any other suggestions are welcome but plz stick to my requirements. thanx. also i have a query regarding time-shift ? what is this time-sift feature exactly ?
my config is on my sig. if anybody requires it. thanx.
i am thinking of going for the PINNACLE PCTV MEDIACENTER 100E ... just want your feedback and suggestions.
