Old 18-09-2004, 02:49 PM   #1 (permalink)
Maverick340's Avatar
Default HELP ME PLEASE.......
I recenlty upgrade my xp..with the cd cause some of my files were missing
After that now whenever i try to put my computer on the boot sctreee appears and waits for a long time and restarts again.....this happens about three four time s and it the loads well
Also my Xp has become realllllllyyyyyyyyyy slow
i have 128 sd ram and have mcafee and zone alarm on startup!
Pls help me
Maverick340 is offline
Old 18-09-2004, 04:46 PM   #2 (permalink)
what do u mean UPGRADE ur xp ??
did u install voer another os or just reinstalled xp over the current on
anyways i think theres a problem with xp .. which ur restore wont fix .. so ull need to do a clean install
No Mercy, No Limits.
theraven is offline
Old 18-09-2004, 06:29 PM   #3 (permalink)
D you mean you upgraded from Xp home to XP pro ?
**** happens
pradeep_chauhan is offline
Old 18-09-2004, 08:37 PM   #4 (permalink)
abhishekkulkarni's Avatar
Dood XP needs at least 256 MB of SDRAM or 128 MB of DDR SDRAM to work properly.That's why your's is really slow.However try disabling all visual effects.That will make it a bit faster.
But all you can do is to buy new ram..
May the source be with you ..
abhishekkulkarni is offline
Old 18-09-2004, 09:22 PM   #5 (permalink)
i got xp wid 128 sdram works fine....n visual fx r not off...
ishaan is offline
Old 18-09-2004, 10:51 PM   #6 (permalink)
LISTEN IHAVE FORMATTED THE HARD DRIVE 9 TIMES AND INSTALLED XP PRO.SEEMS A PIRATED VERSION OF UR'S.SEE I THINK THE FILE THAT IS CORRUPTED IS DDSMORP.DLL OR DVDPLAY.EXE.NO MATTER
INSERT THE XP BOOTABLE CD VERSION THAT IS XP PRO SP1 EDITION THATS IT U ARE ON.DONT INSTALL XP HOME EDITION.THEY ARE NOT AT ALL FRIENDLY WITH UR COMPUTER.TRUST ME DONT IS INSTALL XP HOME EDION.
Writankar panja is offline
Old 19-09-2004, 09:29 PM   #7 (permalink)
i ran sfc and things r better
even it is loading up ffaster!
lock dis topic pls
You and Me forever be ...
PSpwned
Old 23-09-2004, 02:05 AM   #8 (permalink)
sfc?????
Attack life, it\'s going to kill you anyway.
walking-techie is offline
Old 23-09-2004, 03:27 AM   #9 (permalink)
SFC
Slackware : The only GNU/Linux distribution developed on The KISS Principle!!!
Have you been kissed yet? : Get Slack
id10t is offline
Old 23-09-2004, 06:41 AM   #10 (permalink)
ice
SFC= system file checker.
Btw, xp does work with 128mb ram, just needs a hell lot of tweaking,
use hare, free mem/ram xp, and system mechanic.
ice
ice is offline
- by Krow
