Old 05-08-2005, 03:54 PM   #1 (permalink)
Default What is this...?
My conf:
AMD-64 3000+ (939 socket)
MSI RS480M2-IL motherboard - on board ATI Radion Xpress 200 Graphics driver
512 MB - Single DDR Transend RAM 400 FSB (PC 3200)
80GB - Seagate SATA Hard disk
OS- Windows XP Professional SP2
I have formated my Hard Disk recently.
In that time, i installed all of the Drivers, softwares and utilities for Display, audio and video......
I don't know what mistake i did.
Whenever i log on to my system now, there is one new window opening like this,
Welcome to the Found new hardware wizard
when i continue this, This wizard helps you install software for : Display
But i installed ATI Catalyst 5.7 Display driver properly and it works well.
why this window pop-up everytime,
I don't want to come this pop-up window.
what i have to do for this...?
satya_gen is offline
Old 05-08-2005, 11:58 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Give the path to ur display driver setup, when the popup comes again.
If it doesnt work, then u can disable the driver by going to Device Manager and right-click on it and select Disable...
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 06-08-2005, 12:05 AM   #3 (permalink)
siriusb's Avatar
Try uninstalling catalyst and then ati drivers (if u have secondary display, uninstall even that). Restart. Install display driver. Restart. Install catalyst. Restart.
Or, let windows install the device driver. Then go to device manager, right-click display driver, update driver and now point it to catalyst 5.7 inf.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
- by Krow
