Old 18-09-2004, 02:33 PM   #1 (permalink)
Rebooting
Choto Cheeta's Avatar
Default NTFS or FAT32 which is better
I have a 80GB hard drive with 6 partitions.....
C 10GB FAT32
D 10GB NTFS
E 10GB FAT32
F 15GB FAT32
G 15GB FAT32
H 20GB FAT32
I have a dual boot system...... windows 98SE in C drive & windows XP Pro in D that is NTSF.......
My question is, which is the fastest between NTFS & FAT32...... If FAT32 is faster than NTFS then is there any way to convert my D (NTFS) in to FAT32 without reinstalling windows XP & its program files.......
where should I put my page file of windows XP ?? What should be size of the file as I use an AMD 2600+ XP with 256 MB DDR RAM......
Choto Cheeta is offline
Old 18-09-2004, 03:11 PM   #2 (permalink)
JAK
What the Heck !
JAK's Avatar
Default Re: NTFS or FAT32 which is better
Its already answered here....
http://thinkdigit.com/forum/viewtopi...ght=fat32+ntfs
http://www.thinkdigit.com/forum/view...ght=fat32+ntfs
Its always better to hav a dedicated partition for the page file..preferably on seperate HDD(if u hav 2 HDDs). If u dont hav do HDD's its still recommeded to hav the page file on a dedicated partition.
Also having a dedicated partition for the pagefile helps u in reducing the Image size of the OS partition incase u plan to Image it using Drive Image or Ghost...
The ideal size for the page file is 1.5 times the amt of RAM in ur system
u hav 256MB ..so ur page file shud be 1.5 x 256MB = 384MB
although i wud recommend atleast 512MB pagefile size
Risk more than what others think is safe.
Care more than what others think is caring.
Think more than what others think is thoughtful.
Do more than what others think is possible.
JAK is offline
Old 09-10-2004, 11:53 PM   #3 (permalink)
sidewinder's Avatar
NTFS is definitely faster of the two.
Yes its possible to convet the ntfs part to fat without destructive formatting
If u cant use the command line param then use partition magic 8.0 to do so.Its very easy with that software.......just couple of restarts and u r ready to go
But u have win 98 so all ur partitions should be in fat 32
For a system with 256 mb ram a pf of around 384 mb should be enough and optimum
sidewinder is offline
Old 26-10-2004, 03:39 PM   #4 (permalink)
use NTFS for win xp / win 2000 and fat32 for win95 / win98 / win me
C 10GB FAT32
D 10GB NTFS
E 10GB FAT32
F 15GB FAT32
G 15GB FAT32
H 20GB FAT32
Kamaleshwaran is offline
- by Krow
