Old 04-08-2005, 07:08 PM   #1 (permalink)
desertwind's Avatar
Default VRO to MPEG
One of my friend gave me DVD and asked me to convert it to VCDs and I whole heartedly accepted it. But when i put the DVD into my DVD Drive, i found that it is not a standard Video DVD, no VIDEO_TS and AUDIO_TS directories. But i find a directory DVD_RTAV and 3 files in it
VR_MANGR.BUP
VR_MANGR.IFO
VR_MOVIE.VRO
I am able to play the file VR_MOVIE.VRO, but dont know how to convert it to MPEG.
I was using dvd::rip for ripping and encoding my DVDs earlier. I use FC4 as my OS. Please let me know any tools available for GNU/Linux, for converting VRO files to MPEG.
Please dont post about Windows tools. I have had enough from googling. I use no windows!!!
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 04-08-2005, 07:14 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Huh ! VRO ?
Never heard of it...
Wait while i collect some sources...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 04-08-2005, 07:18 PM   #3 (permalink)
Commander in Chief
Mean while , y dont u use a screen recorder and play the movie part by part and then edit them up !
Srry, lame thought
Harsh J
www.harshj.com
Old 04-08-2005, 07:31 PM   #4 (permalink)
siriusb's Avatar
Try the forum post in this link.
It seems it is the default file name in dvdrams and that it is basically a mpeg stream with extra info. The post talks about windows tools to demux, but u can substitute linux counterparts to do the same.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 04-08-2005, 07:35 PM   #5 (permalink)
Commander in Chief
k u got me gain sirius, i could manage to find only a thousand dozen of windows software...
U really should get the brainiac title, y dont u apply for it ????
Harsh J
www.harshj.com
Old 04-08-2005, 07:41 PM   #6 (permalink)
siriusb's Avatar
First, let me see if the OP is satisfied with the answer. Second, all I know is how to google better. That don't say I am brainiac. Thank you anyway.
siriusb is offline
Old 04-08-2005, 10:47 PM   #7 (permalink)
desertwind's Avatar
I find what a VRO file is.
A VRO file is DVD Video Recording Format streaming video file. An associated .IFO file contains the various scene and timing information. This is different from a .VOB file where that information is included in the file. Several manufacturers use .VRO/.IFO files. This is a new specification for real-time recording on DVD discs. The standard DVD specification supports only the playback function. DVD Video Recording Format has several additional functions for recording.
What I cant find is any specific linux tool for converting .VRO to .MPEG.
But later on i found on one forum that it is as simple as that, just used ffmpeg to convert to mpeg.
- by Krow
