well i lost my data and not that is is just not showing but the capacity is also reduced.
i had 107 mb of data then i burned another 489mb of data
now my cd shows only 489 of data.
"Try again, fail again, fail better" - Samuel Beckett
umm....see if ur previous sessions show up on disc information in adaptec's easy cd creator (or equivalent in nero, or watever u use) n then c if u can select that session n save it to the hard drive. if ur able to save it as an .iso(cd image) file or something jus do it then burn it onto another blank cd. might work....
