Old 04-08-2005, 11:08 AM   #1 (permalink)
Default Best Proxy
Which one is the best free proxy? I wanna run bout 25 pcs in a LAN.Currently I m using analoguex & freeproxy but none is satisfactory.
ra_sriniketan is offline
Old 04-08-2005, 11:12 AM   #2 (permalink)
MVP in VC++
you can find some proxy server in the following site.....
http://www.freedownloadscenter.com/B...roxy-free.html
or
you can just try the shareware proxy server
http://www.freedownloadscenter.com/N...xy_Server.html
cvvikram is offline
Old 04-08-2005, 03:01 PM   #3 (permalink)
As far as freebie is concerned I've not found anything better other than AnalogX(which you already have it seems).
If in case you need a commercial solution,try wingate.
It has a trial period I guess,it packs more punch than most commercial solutions available.
http://www.wingate.com/product-wingate.php
www.Oobertech.net
digen is offline
Old 04-08-2005, 03:27 PM   #4 (permalink)
expertno.1's Avatar
okok
among the list provided by cvvikram
which one is the fastest among them ?
expertno.1 is offline
Old 04-08-2005, 04:07 PM   #5 (permalink)
FooBar Guy
GNUrag's Avatar
If you have a geek in your vicinity then you may want to install Squid, the Industry Standard Proxy server. It can do Content Caching as well as Content Filtering. You can install SARG on top of it to obtain beautifully formatted logs of the sites visited and squid usage.
You may want to try 602 Lan Suite which provides features exactly suiting your requirements.
http://www.software602.com/products/ls/
It has a proxy server along with a mail server as well as pop3 maildrop retrieval system.
http://web.gnuer.org
GNUrag is offline
Old 04-08-2005, 05:41 PM   #6 (permalink)
Version 2.0
Deep's Avatar
I doubt about free good proxy software for windows..
but for linux, there is one more version of squid, its customized by indian and I have heard its very good..
Its called as SafeSquid
Butr for windows best paid proxy server would be WinRoute Kerio Firewall..we are using it for 2 years now..and really very satisfied with it..
It can act as normal proxy as well as transparent proxy (where you dont have to enter proxy settings in all machines)
I hope this helps you
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
Deep is offline
- by Krow
