Old 04-08-2005, 12:59 AM   #1 (permalink)
darklord's Avatar
Default Post Your Overclocks !!
Here are some of mine,
Hope you guys like it.
Highest Clock Speed that i have achieved on A64
Highest HTT Speed on A64 that i have managed
My OCZ Ram OC Results -
HyniX DDR400 OC Results -
darklord is offline
Old 04-08-2005, 07:31 AM   #2 (permalink)
Are these stable overclocks. How may hours of Prime and Memtest burn in's have you conducted?.
-Keith
Keith Sebastian is offline
Old 04-08-2005, 08:19 AM   #3 (permalink)
Gr8 Figures there Darky.
Thats 420HTT.
And The best thing is that Hynix going at 303Mhz @ 7705MBps
Running that normal Hynix at DDR606 Speed
Absolutely Unbelievable.
Thats what i like about DFI never limits the spirit of an Overclocker.
Overclock Me.
Overvolt Me.
AMD Me.
quad master is offline
Old 04-08-2005, 10:15 AM   #4 (permalink)
darklord's Avatar
-Keith
Well to be frank when you do extreme overclocking,stability needs to be kept aside.
Even a suicide shot is allowed if the achievement is really extreme.
Well my System is rock stable at following settings -
CPU Speed - 2.8GHz
HTT Speed - 312
LDT Multiplier - 3x
CPU Multiplier - 9x
CPU Core Voltage - 1.56V
LDT voltage - 1.5V
Chipset Voltage - 1.8V
Vdimm - 3.4V
CPU Temps - 42c [Idle] 54c [Full Load]
PWM IC Temps - 41c [Idle] 48c[Full Load]
Chipset Voltage - 48c[Idle] 53c [Full Load]
Memory Specs -
Timings - 2-2-2-5
Command Rate - 1T
Memory Bank Interleave - Enabled
This setup is rock stable,yes Prime Stable,Super Pi 1M test passes,Sisoft Sandra Burn in tests ran for 5 hours.
I guess that counts as stable.
darklord is offline
Old 04-08-2005, 10:17 AM   #5 (permalink)
darklord's Avatar
What...nobody contributing ?.....thats so sad.Come on guys..
darklord is offline
Old 04-08-2005, 02:44 PM   #6 (permalink)
CAS2 timing of 2 is very impressive. I haven't dared go below 2.5 on my Hynix sticks.
Keith
Old 04-08-2005, 02:51 PM   #7 (permalink)
siriusb's Avatar
Does my asus a8ne have ram divider? I have amd64 3200+(winchester) on asus A8NE. I think my overclocks are limited to 2.2GHz(stable) by my hynix ram. I use AI Booster to increase htt. Anything above 2.2 and the pc hangs immediately. My ram is hy5du56422bt-d43.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 04-08-2005, 04:30 PM   #8 (permalink)
impressive results indeed ! altho i m not too much into overclocking myself...
my system (config below) ...I cant even run the Ram at 1T command rate at stock 3-3-3-8 timings forget overclocking ( any pointers?
A64 3200 winnie + 512*2 KVR 2.5-3-3-6 2T + MSI K8N SLI platinum - Creative SB Live! 7.1 + Leadtek PX6600GT 550/1125 + 160 GB Seagate N.C.Q. + 320 GB WD + LG 17" CRT
3Dmark05 - 4008 3Dmark03 - 8,983
Ringwraith is offline
Old 04-08-2005, 04:34 PM   #9 (permalink)
Your ASUS A8N-E is a gr8 motherboard for overclocking.
Also dont overclock with AiBooster.
Use BIOS for overclocking.
Gradually increase your FSB in 5Mhz
Also your motherboard is one of the best for OCing
Its has DDR Dividers for sure.
Also there might be other factors that might be affecting your overclock lile ram timings
If they are too tight you need to loose them up.
To like 2.5-3-3-7 or 3-3-3-8 to overclock the ram with CPU.
Orignal Hynix having D43 Chip reach 250 atleast.
But Darky managed 303 with his Hynix on his
masterpeice DFI Ultra-D.
Overclock Me.
Overvolt Me.
AMD Me.
Old 04-08-2005, 04:45 PM   #10 (permalink)
my OC is in my signature. The CAS timings which I have as of now on my kingston is 2-3-3-6 and it does not run any lower. Pretty happy with the performance till now. Lets see what happens when I get my new pdp memory on friday hehehe.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 04-08-2005, 05:30 PM   #11 (permalink)
darklord's Avatar
Well those timings are on my OCZ Ram and not Hynix.I have posted the Hynix Screeny just to show the results.
the one with 2-2-2-5 is on my OCZ VX Ram.
I dont think Hynix is capable of doing CAS 2.
Asus A8N-E has RAM Dividers.They are named differently though.In Dram Config,keep Memclock Mode to DDR200 so your Ram will work at DDR 200 instead of 400 so you get a lot of headroom with the RAM not hindering your OCs.
Do NOT use AIBooster,its pretty useless.You could OC thru BIOS and to earn the last few MHz, use Clockgen,This can be found here - www.cpuid.com
Relax the timings of your RAM to 3-4-4-8.The ram you have is Hynix D43 and it like loose timings not tight ones.
my system (config below) ...I cant even run the Ram at 1T command rate at stock 3-3-3-8 timings Sad forget overclocking Sad( any pointers?
Tried updating the BIOS ?
May be that will help.
darklord is offline
Old 04-08-2005, 05:42 PM   #12 (permalink)
yeah dont have net connection as yet but i think uve hit it right!
Old 04-08-2005, 05:47 PM   #13 (permalink)
darklord's Avatar
Many boards had the 1T issue,which was solved with BIOS updates.
AFAIK DFI could do the 1T thing correctly from the beginning.
darklord is offline
Old 04-08-2005, 10:03 PM   #14 (permalink)
siriusb's Avatar
Thanks all, I hit 2260MHz with nothing else changed but only increasing the ddr voltage up one lvel.
But I am having trouble increasing it more than this. My ram timings are bad as it is by default at: latency=3, ras=8, ras-to-cas=4, mem bank switch=4.
If i did the same increase in clock with ai booster, my comp freezes. So never again with ai booster.
In ai booster, I can increase cpu voltage above 1.55V but in bios 1.55 is the max. Is this ok? Do I have to increase voltage of cpu if i increase clock? or shud I decrease it?
Shud I do anything with HT link multiplier (currently at x5)?
What about ddr voltage? If I change my ddr freq to 200, shud I decrease or increase the volt?
I read somewhere that if I have to OC in a8ne, i have to connect my sata in ports 3 and 4 to improve stablity. Will that help for my small overclocks? Anyway, I can't migrate to the other controller, as I have raid0 ed the satas and have my os in that.
siriusb is offline
Old 05-08-2005, 01:54 AM   #15 (permalink)
Gr8
Whats the VDimm you are feeding into that ram and what ram do u have.
If you find that your ram is restricting your overclock then use DDR Divider.
How to use DDR Divider Read here:- http://www.thinkdigit.com/forum/viewtopic.php?t=26008
Always use BIOS for system overclocking.
Which CPU do you have Venice or Winchester.
1.55 might be more.
Also when you overclock your CPU to a higher value you need to increase
the Vcore or CPU Voltage for the CPU to be stable
HTT multiplier doesnt have huge impact on the performance.
Whenever the HTT is increased from
200 to 250 it shud be 4
250 to 333 it shud be 3
The main reason is that the HTT Speed shud not exceed 1000Mhz
200 x 5 = 1000
250 x 4 = 1000
333 x 3 = 999.99
Increase the Vdimm with increse in FSB or HTT but it is depended on the
Ram chip used by the ram.
Note:- only increase the voltage of Vcore and VDimm only if you find that
your system is unstable.
Also use software like memtestx86 to test mem stability at overclocked speed and prime95 to test CPU stability.
Prime 95 Small FFT Test for atleast 12Hrs to test stability of the overclocked processor.
Overclock Me.
Overvolt Me.
AMD Me.
Old 05-08-2005, 05:21 AM   #16 (permalink)
siriusb's Avatar
Thanks quadmaster and darklord for your enlightening response. Right now I just decreased my ram to 333MHz, ddr volt to 2.6V, HT to 4x and htt to 250. So now my cpu is running at 2500MHz and fsb at 1000MHz.
I wanted to increase htt more, but I want to see the stability of the current clock first. I am kinda dazed at the cpu freq here. Right now it is priming.
I want to know how the multiplier(currently at 10) plays a part here.
@quadmaster,
I have a winchester core 3200+. And at ddr400, I increased from 2.6V to 2.7V to acheive that speed.
It's kinda mind boggling to see the number of parameters in dram settings. I know two or three settings here, but not all. Do I have to know them to OC better?
I have another question. To acheive this speed, I had to lower ram performance, right, so will my benchmarks be faster or not? I understand that u have to go for better quality ram for ocing to avoid lowering settings, but I just wanted to ask.
siriusb is offline
Old 05-08-2005, 08:12 AM   #17 (permalink)
Wow its nice to see that i was of help to someone to get 2500Mhz thats nice. a 500Mhz OC.
Your chip can do more but first test stability.
Also keep an eye on Temps.
CPU multiplier role , very simple 250x10=2500Mhz
Also Running ram at lower speeds u get little less perf after all u can get everything from value ram.
Gr8 Ram Timings Guide here:- http://www.dfi-street.com/forum/showthread.php?t=11397
You will understand every ram timing after reading this.
So how do u feel after overclocking that cpu to 2.5Ghz.
Overclock Me.
Overvolt Me.
AMD Me.
Old 05-08-2005, 10:32 AM   #18 (permalink)
darklord's Avatar
Well Congrats on your 2.5GHz OC.Good effort.From what you ahve achieved, you seem to have a decent enough Winchester Stepping.
Anyways,you have mentioned that you SATA RAID and OS installed on it.
If possible,remove those drives[only while OC'ing] and install a 40 GB or any older PATA Drive.
SATA and OCing,isnt that good a combo.Although the SATA on NF4 isnt that quirky as NF3 but still.
So i suggest you do so to avoid RAID collapse or OS crashes.
Also be ready to face some OS crashes once you enter the extreme OC zone.
Now coming to the RAM issue,dont botther too much about it,if you have cheapo ram,dont worry,use dividers to run it at DDR200 so you dont have to worry about OC dumps due to Memory.
Now reduce the HTT/LDT Multiplier to 3X to be on the safest side.
and keep the Equations Quad has mentioned above always handy.
Most important is the HTT one.
Never let the HTT speed cross 1000.1020 HTT is OK but avoid if possible.THats why i told you to reduce it.That will remove another headache from your Mind and you can concentrate on Pure CPU OC.
Asus A8N-E is an excellent board.I say this from my experience.My previous Highest Personal OC on A64 was on it,2.82GHz to be precise.
THat board has Immense potential,use it.
Best Of luck And Happy OC'ing.
And about stability,i dont give a damn about it as practically you dont use thsoe speeds.Reasons for the same are various.
SO my ultimate aim is to see how i can go.
Even if your OC is benchable in Sandra,Everest..its good enough.
Dont forget to run SuperPi 1M test, it is very very sensitive,if it passes,you have a pretty stable OC.
Also when you cross the line and start doing Extreme OC,stability and all crap goes in the trash can,so to hell with it.
Hehehe.
Coem on man,go go go....
Keep your Target at 2.7 now.
darklord is offline
Old 05-08-2005, 10:52 PM   #19 (permalink)
siriusb's Avatar
I must've restarted more number of times today than all the other days combined. But I don't seem to get any faster than 2500MHz. But now I have increased back to 400MHz, so I guess it a bit better than my previous blind attempt. My ram has all the timings except the first three, as the maximum by default. It is a mark of a cheap ram, is it?
I had increased all the timings and freq to the max, but still the comp won't boot even at 2550MHz.
Here'a a screen shot I made juat after a 4M superPI. For some reason, the superpi font is illegible. I hope it went alright.
Thanks to both of ya guys for showing me the path
2.7GHz seems a long way now.
One question. I read somewhere that getting a blue screen means that u must increase ur vdimm or vcore. Is this true? and if so, which (vdimm or vcore) shud i increase? And another question: Is my mem and fsb running in sync?
siriusb is offline
Old 05-08-2005, 11:27 PM   #20 (permalink)
hey dark btw do u use some sort of different hsf or the one provided with the cpu????
magnet is offline
Old 06-08-2005, 08:20 AM   #21 (permalink)
If your computer doesnt post
then u have to increase your Vcore or CPU Voltage
to the next number.
same applies for ram.
But i warn u that keep an eye on the temps.
Also do u have the default cooler or have different cooler like ASUS Starice or Coolermaster Ultra Vortex.
@ Magnet - For mild overclocks like 400 - 500Mhz extra on 3000/3200 stock
cooler is fine unless temps are kept in control
You should use a cooler like ASUS Starice or Coolermaster Ultra Vortex as they control your temps for overclocks above 600+ Mhz.
Every cooler is fine till the temps are in control.
Overclock Me.
Overvolt Me.
AMD Me.
Old 06-08-2005, 09:37 AM   #22 (permalink)
darklord's Avatar
@ Magnet
I generally use Stock cooler.the 2.9GHz thing was done with CM Ultra Vortex but it isnt any better than the stock cooler.
darklord is offline
Old 06-08-2005, 10:53 AM   #23 (permalink)
siriusb's Avatar
I use the default cooler. Tell me, is there a sacred temp for cpu/ram above which you shouldn't subject a 3200+/hynix? Coz I read this somewhere: ""Lets say you were in the desert and it's 108 degrees, you grab onto a power line, you get electrocuted. Now, lets say you were in Antarctica it's -36, you grab a power line, you STILL get electrocuted"
Kinda funny actually.
My cpu idles at 44deg and at 100% it's 56deg. I have QFan at 54. I can't monitor the ram, so I guess I must controll my vdimm?
siriusb is offline
Old 06-08-2005, 11:03 AM   #24 (permalink)
Commander in Chief
QwertyManiac's Avatar
can u overclock an original Intel ???
Harsh J
www.harshj.com
QwertyManiac is offline
Old 06-08-2005, 12:08 PM   #25 (permalink)
siriusb's Avatar
Originally Posted by QwertyManiac
p.s. Siriusb - y r u hidin yr online presence ???
I never hide from online presence. Whatever gave you that idea? And why wud u want to see me online? U can pm me anytime.
siriusb is offline
Old 06-08-2005, 12:14 PM   #26 (permalink)
Commander in Chief
no i mean , i dont see u on the members currently online...
As for PMing, they sux as i m alyays not allowed to do one but i recieve without permission...
Well, bout my intel problem ....
Harsh J
www.harshj.com
Old 06-08-2005, 02:27 PM   #27 (permalink)
darklord's Avatar
Well there is no way to check RAM temps.CPU temps are ok if they are in the 50-55c range.
I guess you have A8N-E board,this board doesnt support Vdimm above 3.0V
so RAM heating isnt an issue for you as you have Hynix and not Winbond.
:roll: :roll: :roll:
There is no way to overclock Original Intel Motherboards.
darklord is offline
Old 06-08-2005, 02:43 PM   #28 (permalink)
Before u try anything , ne sort of damage caused in not my responsibility
Stock Intel overclocking
There is a hidden option on some stock intels
Try and find an option called burn in mode in advanced settings in BIOS.
And here you can overclock your sustem in %
pretty simple.
Dont remember the % values its till a max of 10 or 15%.
Also Try a software called clockgen for ur respective motherboard and overclock ur Intel from windows.
Thats all ur options.
Keep an eye on the CPU Temp with MBM 5 / Speed Fan
You can check ur CPU speed in CPU-Z
Overclock Me.
Overvolt Me.
AMD Me.
Old 06-08-2005, 03:27 PM   #29 (permalink)
siriusb's Avatar
Hey quadmaster, post your OC here too. I saw many guys supporting dfi in some poll here. I hope they notice this post too.
I also wanted to know if my fsb and mem are running in sync.
siriusb is offline
Old 06-08-2005, 03:31 PM   #30 (permalink)
darklord's Avatar
From the Screenshot that you have posted, yes your RAM and HTT is in Sync,meaning it is running 1:1
darklord is offline
- by Krow
