Old 03-08-2005, 11:49 AM   #1 (permalink)
tweety_bird_bunny's Avatar
Default found what?????
recently my pc shutdown abrubtly...on restarting it scandisk began..
when i logged in my XP a directory such as found.000 was formed in c: drive??? it contained many files...what is that ?shall i delete it ..or is it any use to me??
tweety_bird_bunny is offline
Old 03-08-2005, 12:53 PM   #2 (permalink)
QA Juggler
saROMan's Avatar
well these are the lost chains of data that XP found during Scanning..so it converts them in to files like .000 , 001 etc...you can detele them safely....
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 03-08-2005, 01:31 PM   #3 (permalink)
MVP in VC++
Yes you can delete these files without hesitation.
cvvikram is offline
Old 04-08-2005, 08:54 AM   #4 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
uhmmm... the files are those lost clusters found normally when scandisk is done automatically.
It might b a file which was in use while the computer was switched off suddenly. It might b important files.
Most of the files we want are larger (in terms of 100kb or more). So see if u missed some files... try changin the extensions of the files *.000 to some well known extensions like zip,dat,doc,txt... and run them... u might find some really useful files u might have just missed... or directly open them using the respective sw... like media player, word, winzip...
koolbluez is offline
Old 04-08-2005, 07:18 PM   #5 (permalink)
Distinguished Member
anandk's Avatar
i concur. u can delete the files safely.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 04-08-2005, 07:20 PM   #6 (permalink)
Commander in Chief
QwertyManiac's Avatar
yep those files r k ta delete...
Safe
Harsh J
www.harshj.com
QwertyManiac is offline
Old 05-08-2005, 08:44 AM   #7 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
There are chances of losing imp files if u were workin on them during abrupt powershutdowns or computer shutdowns... Then also go into the found.000 set...
So u better arrange these files w.r.t size and start openin them from the largest file first... esp those above 100kb... using 'Open With' with common applications like ms word, winzip, media player... Also try changing them to .exe and run them...
Definitely worth a try, baaki tumhari marzi...
- by Krow
