Old 03-08-2005, 03:43 AM   #1 (permalink)
Default computer not starting no beep
when i switch pc i see hard disk light blink and power supply light comes.
but did not hear any beep of computer.
my computer didnt start
i saw somewhere that if none Beeps is there then
Power Supply or System Board failure may be there
what is that
Power Supply
i have opened computer and tight all card memory in my computer to see that nothing is loose
then computer worked
now again after 2 days it stopped
i once agian open case and tight all card memory in my computer and it started
why this happens
i have pentium 166 mhz 1997 computer .i have award modular bios 4.51 version bios
it is giving problem from 10 days only
AMIT AGARWAL
AMITAGARWAL02 is offline
Old 03-08-2005, 09:12 AM   #2 (permalink)
Power Supply --> SMPS
System Board --> Motherboard
A beep indicates succesfull POST, so If it doesnt beep, check whether the fan on the smps is on ?
SMPS may have a problem.
Most of all just check whether ur computer is pugged in and the switch is on, esp if u have a stabilizer and no UPS the residual power may just blink the lights on, ofcourse the computer will not start , no its not funny , this has happened.
Hey hows Kalyan now ?
Huzefa is offline
Old 03-08-2005, 02:18 PM   #3 (permalink)
Thanks for the reply
yes fan is running yes both fans.
and computer runs sometimes
yes done that without
stabilizer and UPS but nothing happens
if SMPS has problem then light is coming in computer fan is running cd rom and hard disk is running then what to do if smps has problem
i can call computer person but i think they may not come to place soon because of flooding all over
kalyan is not ok
AMIT AGARWAL
Old 03-08-2005, 03:11 PM   #4 (permalink)
Did you overclocked your CPU or GPU?
Delpiero is offline
Old 03-08-2005, 05:57 PM   #5 (permalink)
Version 2.0
Deep's Avatar
hmm looks like problem with RAM, i had faced same problem few days back and later I found that one of my momory stick was gone...
check with hardware guy and see what he can do..
my suggestion before calling hardware guy: try removing your memory sticks and fitting then again..
if that doesnt work then....if you have 2 sticks on mobo then try removing one of them and try to run the pc on one RAM, cross check the same by interchanging both the sticks..
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
Deep is offline
Old 04-08-2005, 12:25 AM   #6 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
Ive helped one of my friends previously with a similair problem. His motherboard was fried though...
Usually it ends up to be a problem with your motherboard , SMPS or RAM.
Check this thread out. It has the above scenario listed in it...
http://www.mysuperpc.com/build/pc_fi...problems.shtml
Hope it helps.
FilledVoid is offline
Old 09-08-2005, 03:10 AM   #7 (permalink)
Thanks now i have purchased new computer
pentium 2.4 ghz 6500
845 gv motherboard 3500
512 ram 333 mhz 2800
40 gb harddisk 2750
mouse 450 Mercury optical KOB 333 model
keyboard 450 TVS
cabinet with 300 SMPS 1800
18250
PLUS octrio 730 so 19000 RS
is this the right price i paid for this system
I purchased 3 days ago
also where to sell old 166 mmx pentium with 64 mb ram computer now computer is working properly
AMIT AGARWAL
Old 09-08-2005, 03:11 AM   #8 (permalink)
i also want to purchase another computer as i am selling mine
pentium 600 with 256 mb ram computer
actually i want latest motherboard and cpu
but i want to connect old drives
i have 2 hard disks
1 cd drive
1 cd writer
actually vendor told all new motherboards that supports high cpu has only
1 IDE port so u can connect only 2 old drives that u have
can any one guide me is there any motherboard that has 2 IDE ports
I dont want sata port
also i want to run nfs u2 and and many latest games
thanks
AMIT AGARWAL
Old 09-08-2005, 04:39 AM   #9 (permalink)
siriusb's Avatar
U can get an Asus A8N-E with Amd64 3200+, 1G ram and a decent video card like 6600gt or 6800 according to your budget.
There are two ide ports on the latest mobos, but one is the hdd port and other is the cdrom port. You can always connect hdd and cdrom drives in the others' port too. You might lose some bandwidth from the hdd, but you can connect them atleast.
To conect more ide devices, you can buy yourselves an pci ide card that has two extra ide ports. Or, you could buy urselves an external hdd casing and attach hds via usb.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 09-08-2005, 06:05 PM   #10 (permalink)
i am using
MSI K8N neo Platinum
(i had to buy it as at that time amd 939 socket procc was not out)
well u can go for
MSI K8N Neo2 platinum as it supports 939 socket
and moreover u can connect 4 ide drives and 4 sata drives
Aviation (Aircraft Maintenance Engineering)
http://www.ame-world.frih.net
Sankalp is offline
Old 09-08-2005, 06:11 PM   #11 (permalink)
i am using
well u can go for
Sankalp is offline
Old 09-08-2005, 06:13 PM   #12 (permalink)
but Sankalp which cpu it supports
i want latest cpu like 3.0 or 3.2
AMIT AGARWAL
Old 11-08-2005, 04:15 AM   #13 (permalink)
40 gb harddisk 2750
keyboard 450 TVS
18250
I ran need for speed underground 1 on this pc
frame rate was ok in normal settings i think they where 20 frames per sec
if i add graphics card how much frame rate will go
please tell me graphics card in range of 3000 to 7000 rs
AMIT AGARWAL
Old 11-08-2005, 04:42 PM   #14 (permalink)
GetUserTitle()
huzaifa b arab's Avatar
A XFX - 256MB GEFORCE FX 5700 AGP Card shall be good.....
Price : Rs. 6000/-
If u wanna buy it i'll give u the link....
Here it is
http://computerwarehousepricelist.co...list.asp?ctg=6
*Thinks of a witty one-liner...still thinking*
huzaifa b arab is offline
Old 13-08-2005, 03:06 AM   #15 (permalink)
Thanks huzaifa b arab
very much
but from 20 frames per sec now
how much frames per sec i will get
if i add this 2 cards (from this 2 any one)
Frames per sec will go upto how much approx for
XFX - 128MB GEFORCE FX 5200 AGP Card
Price : Rs. 2500/-
Price : Rs. 6000/-
i play nfs u and nfs u 2 i mean racing games only
thanks for the reply
ALSO CAN ANY BODY PLEASE SEE MY ABOVE POSTS AND TELL ME WHETHER I PAID CORRECT PRICE FOR MY SYSTEM PLEASE PLEASE
THANKS
AMIT AGARWAL
Old 13-08-2005, 05:38 AM   #16 (permalink)
The price that you paid seems pretty reasonable. However i would recommend against going in for a FX 5700 for Rs. 6000, as u can get a Geforce 6600 for about the same price. With a 6600 you will get much better image quality then right now.
wolfff is offline
Old 13-08-2005, 10:23 PM   #17 (permalink)
it supports even a athlon 64 FX
so dont worry abt 3.0 or 3.2
Sankalp is offline
Old 22-08-2005, 02:29 AM   #18 (permalink)
I have replaced pentium 166 mmx with this one
40 gb harddisk 2750
keyboard 450 TVS
18250
i will be replacing pentium 600 mmx computer with new one
i want to buy better computer than the one i have bought
i want 7.1 sound
the machine i have bought have 5.1 sound and intel extreme graphics
please tell which motherboard have
7.1 sound
intel extreme graphics 2
support for 4 ide drives
thanks
any other thing i have to considered buying for new machine tell me
AMIT AGARWAL
Old 26-08-2005, 12:33 AM   #19 (permalink)
Can 300 or 350 power is enough for above configuration
actually branded cabniets have 300 or 350 power supply of their own
thanks
i also want to attach graphics card
i have 4 ide drives
AMIT AGARWAL
- by Krow
