Old 02-08-2005, 08:19 PM   #1 (permalink)
Distinguished Member
anandk's Avatar
Default help me 'unhide' the local settings folder...
in (my) winxp/sp2, the C:\Documents and Settings\ACK\Local Settings
always appears 'hidden'. i want it to be shown always. so in its properties, i unchecked the 'hidden attribute' and applied. the attributes were applied. sure it was shown.
but when i restarted, it again reverted to being 'hidden'.
anyway i can make it permanently 'shown' ???
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 02-08-2005, 08:28 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
May be because of the desktop.ini file situated in that folder.
Try to remove the 2nd line from this file, saying LocalizedResourceName..........
U can also try to set the attribute unhidden only for the main foler Local Settings and not for its sub-directories and files.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
- by Krow
