| Forum |
#1 (permalink) |
#2 (permalink) |
Its not a problem with multiplication. This is a problem with ur motherboard. It is not showing 30 GB. I also saw this problem in my friend's system. His vendor said that some motherboard are not fully compatible with hdd with greater space. He gave some patch (came in a floppy only). After that it recognised the full space. I dont remember the exact incident. U can inform ur vendor. He must be known about this problem.
#3 (permalink) |
the motherboard is pretty new.i ve just got a new computer with an AMD 64 2800 and an ASRock motherboard(K8Upgrade-VM800)
anyways i think i ve found the solution. i just have to try it out after installing xp. basically i need to install sp1 and tweak some registers. here are the links i found helpful if anyone's interested: The motherboard FAQ's site: http://www.asrock.com/support/FAQ/in...ss=General-HDD other sites: http://www.the-scream.co.uk/forums/t8905.html http://groups.google.com/group/micro...&output=gplain http://www.abxzone.com/forums/showth...threadid=37938 |
| Bookmarks |
| Display Modes | |
