Old 17-09-2004, 11:52 PM   #1 (permalink)
Default FAT 32 to NTFS!
I'm running Windows XP Professional with SP 2 installed. I'v got a 40 GB HDD with three partitions, C,D and E, C being the primary(system) partition. The D & E drives are configured with NTFS file system but my C drive has FAT32 file system. Is there any way of changing the file system to NTFS without re formatting the partiton and re loading windows?
indrajit is offline
Old 18-09-2004, 12:06 AM   #2 (permalink)
ya there is one through DOS
but i suggest not to do it(not due to data loss but due to cluster size)
any way here is the way to do so
go for
run->command
in command prompt type(only in winXP)
convert/?
this will give u all the details in simple manner u can do it like
convert c: /fs :ntfs
Music is like Sex, The more you get, the more you want.
demoninside is offline
Old 18-09-2004, 12:09 AM   #3 (permalink)
JAK
What the Heck !
JAK's Avatar
Default Re: FAT 32 to NTFS!
Go to Start--> RUN and type " cmd" without the quotes...
then type
"convert c: /fs:ntfs " with out the quotes...
It will prompt u to do it at next reboot ..say yes...
Risk more than what others think is safe.
Care more than what others think is caring.
Think more than what others think is thoughtful.
Do more than what others think is possible.
JAK is offline
Old 18-09-2004, 12:10 AM   #4 (permalink)
i think win xp gives an option to upgrade to ntfs try right click and see (sorry i am in debian right now so cannot confirm it)
**** happens
pradeep_chauhan is offline
Old 18-09-2004, 01:07 AM   #5 (permalink)
parthbarot's Avatar
simple
convert command in dos
www.techlads.com
Paarth.
parthbarot is offline
Old 18-09-2004, 02:32 AM   #6 (permalink)
then type "convert c: /fs:ntfs " with out the quotes...
perfect solution .. just an addition to the msg. . it'll say u need to unmount the drive and whethere u should force it to unmount .. ofcourse choose no ... then it'll give u the restart option .. that time click yes
and next time search the forum
right here === > http://www.thinkdigit.com/forum/view...ght=fat32+ntfs
see ??
No Mercy, No Limits.
theraven is offline
Old 18-09-2004, 01:34 PM   #7 (permalink)
abhishekkulkarni's Avatar
Tell me guys if i convert an existing FAT 32 partition in to an NTFS one by the method spoken about above , will i lose the data on the fat 32 partiton?
May the source be with you ..
abhishekkulkarni is offline
Old 18-09-2004, 02:49 PM   #8 (permalink)
JAK
What the Heck !
JAK's Avatar
Nope u shall not lose any data....
JAK is offline
Old 18-09-2004, 02:51 PM   #9 (permalink)
Thor's Avatar
Absolutely not. I've done it myself.
SO go ahead make ur day.
Beware of my Wrath Mortals, Thou hast no choice.
Thor is offline
Old 19-09-2004, 01:16 AM   #10 (permalink)
#/bin/sh's Avatar
http://linux-ntfs.sourceforge.net/info/ntfs.htm
\"99 little bugs in the code, 99 bugs in the code, fix one bug, compile it again, 148 little bugs in the code. 148 little bugs in the code....\"
#/bin/sh is offline
Old 19-09-2004, 01:25 AM   #11 (permalink)
I wonder what linux has to do with this thread ?
**** happens
Old 19-09-2004, 02:07 AM   #12 (permalink)
what so ever convert command is for converting without loss
but yes it \\\\\\?????????????????
Old 23-09-2004, 02:09 AM   #13 (permalink)
so indrajit !! finally was ur problem solved !!!
Attack life, it\'s going to kill you anyway.
walking-techie is offline
Old 23-09-2004, 06:48 AM   #14 (permalink)
ice
But converting like this wont give u all the benefits of NTFS, for true NTFS properties, ull need to format and reinstalll. and choose NTFS as the FS while installing.
ice
ice is offline
- by Krow
