| Forum |
#2 (permalink) |
Manchester United
For a basic PCI-x card, you can try ATI X300 SE, for latest prices check www.npithub.com. It should not cost you more than 5000 bucks.
PS3-Ipod Touch 4G-Samsung Galaxy Ace-Sapphire HD 6870 Twin Frozer-Creative Zen
#4 (permalink) |
160gb seagate sata ncq for 4150 i took in delhi
in mumbai price might be lesser somewhere also,which 939 mobo supports ddr 2? tell purpose,budget and components to buy for gaming get 2gb ram opr atleast 1gb
Core i7 2600k|Gigabyte P67A UD4 B3|Corsair XMS3 2x4GB|HD6970|Coolermaster SilentPro 850M|Coolermaster HAF 932|Audioengine AE5|Samsung Galaxy S|Samsung Galaxy Tab 3G|Blackberry Curve 8520 |
#5 (permalink) |
My usage will be Multimedia, Little gaming, Photoshop, etc. so tell where can i go for. As for as gaming concerned i may buy a good graohics card l8r, so too match dat good graphics card i need a good proccessor on 64 bit plaform now. also tell me the price of AMD athlon 64 3200+, 3500+, 3800+ on 939 pins
#7 (permalink) |
Approx costs:
3200+(939) => 8.6K 3500+(939) => 14K 3700+(939) => 21K 3800+(939) => 23K -There's no amd mobo that supports ddr2. -For gaming, 1Gb is the maximum that is needed. -The best card for main stream gaming is BIG 6600gt (128MB) -If u want on-board grafx mobo, go for MSI rs480 il mobo. Else, u can check out asus a8ne.
http://myxp.blogspot.com ----------------------- Winchester 3200+ @2,500MHz LeadTek 7900GT VOLT MODDED @ 680 core, 1800 mem 2x1GB Transcend DDR400 @ DDR454 2.5,3,3,5,1T |
#8 (permalink) |
dunno the prices in chennai..but i got the following in hyd...(i think prices are prolly on the higher side
Amd 64 3200+ (939) = 9,400 MSI K8N SLI Platinum 10,500 Leadtek 6600GT extreme ed. = 11,500 160GB Seagate SATA = 4100 512 * 2 Kingston RAM = 5,200
A64 3200 winnie + 512*2 KVR 2.5-3-3-6 2T + MSI K8N SLI platinum - Creative SB Live! 7.1 + Leadtek PX6600GT 550/1125 + 160 GB Seagate N.C.Q. + 320 GB WD + LG 17" CRT 3Dmark05 - 4008 3Dmark03 - 8,983 |
#10 (permalink) |
for socket 939 go for Asus A8N-E motherboard. The board is based on NForce4 chipset and is future proof for the next 2 or three years....comes loaded with pci-express and sata II support. ready for athlon x2 dual core processor with a simple bios upgrade. if u r into heavy graphics then consider asus a8n sli deluxe. all the above feature plus dual pci-e support
Price Asus A8N-E Rs. 8800/- Asus A8N SLI Deluxe Rs. 12000/- |
| Bookmarks |
| Display Modes | |
