Originally Posted by hansraj
can anyone help me ...... i think its some virus attack which replaces the notepad.exe in the system32 folder in the xp operating system... everytime i have to replace the new unknown defected notepad.exe by the original one so as to open the txt files again using the notepad... n the problem starts again after i surf the net
This problem is due to a spyware.
install and run Adaware SE Pro.
and after that, go to the folder C:\windows\system32\
you will find the file --
notepad.exe (the one with icon) renamed as something like
notpad.exe
rename that back to the name
notepad.exe to solve the problem.
