Old 01-08-2005, 08:46 PM   #1 (permalink)
Default GRAPHIC CARD!!!! Qn
ASUStek V9400-X/TD
Graphics Engine NVIDIA MX4000
Video Memory 128MB DDR /64MB DDR
Engine Clock 250MHz
Memory Clock 400MHz (200MHzDDR)
RAMDAC 400MHz
Bus Standard AGP 2x/4x/8x
Memory Interface 64bit DDR / 32bit DDR
Max Resolution 2048x1536
VGA Output Standard 15-pin D-sub
DVI Output DVI-D
TV Output Composite output
3yr warranty
Im getting it for Rs.2900
Is it a good card?? How is it compared to geforcefx 5200 nd other cards?
What difference between asustek geforce 4000....nd normal/other geforcefx 4000?
wats diff between asus drivers and nvidia drivers?which is better?
I dont understand the branding of these graphic cards...!!
chillnow is offline
Old 01-08-2005, 11:05 PM   #2 (permalink)
darklord's Avatar
you are better off with a Asus 9200SE which costs around the same price but is a far better GPU
darklord is offline
Old 01-08-2005, 11:30 PM   #3 (permalink)
Wake up man FX5200 is better than it.
XFX FX 5200 64 bit - Rs 2200
XFX Geforce FX 5200 128bit - Rs 2700
Mahesh Babu is offline
Old 01-08-2005, 11:39 PM   #4 (permalink)
darklord's Avatar
When did i say 9200SE is better than FX 5200 ? :roll:
This guy was talking about Asus cards so suggested him something in the same range,thats all
darklord is offline
Old 02-08-2005, 08:15 AM   #5 (permalink)
deathvirus_me's Avatar
hey the 6200's cost only around 3800 now-a-days .. so why would anyone get FX5200 ???
deathvirus_me is offline
Old 02-08-2005, 08:23 AM   #6 (permalink)
Thats PCI-X TC version
AGP version is Rs 5400 128bit
Old 02-08-2005, 09:33 AM   #7 (permalink)
darklord's Avatar
Well the 6200 doesnt come in 128 Bit in AGP afaik
Its available in PCi Express though.
darklord is offline
Old 02-08-2005, 09:43 AM   #8 (permalink)
firstly for that range you won't get a decent card
Secondly whatever you do make sure memory interface is not less than 128bit,if possible 256bit
for all cards (including specified blw).If you find a below mentioned card without 128bit memory interface or higher then don't take it.
Consider
128mb/256mb FX 5200 or ultra(if existing now or if existed in a particular model)
128mb/256mb FX 5700le or better versions
128mb/256mb geforce 6200
128mb/256mb radeon 9600se
128mb/256mb geforce fx 5600 or ultra
FX series is crap and so is 9600se is useless.
also,is radeon 9550 dx 9.
take dx 9 or better cards
preferably dx 9c
fx don
t have full suport for dx 9 nah?
akshayt is offline
Old 06-08-2005, 01:03 PM   #9 (permalink)
err.....i had already bought the card before posting...i was just checking how my graphic card is in comparison and in price....to make sure iv not been duped.
chillnow is offline
Old 06-08-2005, 03:27 PM   #10 (permalink)
darklord's Avatar
Then you should have mentioned so specifically.You havent done so anywhere.
darklord is offline
Old 06-08-2005, 05:41 PM   #11 (permalink)
no its not ....
XFX GeForce 6200 128mb 64bit mem. agp8x costs 3800 bucks ...
the 128bit ver. costs around 5400 .....
