Old 01-08-2005, 06:32 AM   #1 (permalink)
Default VCD making
Hi Guys
Problem No.1. whenever I create a VCD through Nero the cd does not run smoothly. It kind of stops, screeches and runs again with the picture geeting distorted at times.
Problem No.2. When capturing a video from PCTV the audio runs a few seconds later than the video i.e. the lips seem to move before the sound is heard
thnks for ur time
manish
Manish
manishji is offline
Old 01-08-2005, 07:39 AM   #2 (permalink)
q3_abhi's Avatar
Whats ur machine cconfiguration????
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 01-08-2005, 07:57 AM   #3 (permalink)
hack expert's Avatar
prob 1
check wether the movie or video ur burning is good if the video is already distorted then it can cause problems
also does every vcd u create get the prob or only a few ???????
prob 2
the prob herre is sound lag i havent used pctv however u can check the settings for sound and adjust the lag as required
If electricty comes from electrons, does morality come from morons?
Flying is simple. You just throw yourself at the ground and miss
hack expert is offline
Old 01-08-2005, 04:11 PM   #4 (permalink)
Default config
I am using windowsxp(sp2) on a p4 machine with 2.4GHz with 256 RAM and 40 GB HDD. My original video is fine in MPG format but the burnt vcd is jerky and this happens for all vcds burnt.
thanks again
manish
Manish
manishji is offline
- by Krow
