Old 31-07-2005, 10:33 PM   #1 (permalink)
tuxfan's Avatar
Default PHP & HTML forms - Pl help resolve basic problem
I am getting an error in PHP. What's wrong? Its on Win98SE, Apache 2.0.54, PHP 5.
Here's forms.htm file
<html>
<head></head>
<body>
  <form action="forms.php" method="GET">
    <input type="text" name="user">
    <textarea name="address" rows="5" cols="40"></textarea>
    <input type="submit" value="Submit">
  </form>
</body>
</html>
Here's the forms.php file
<html><head></head>
<body>
  <?php
    print "Welcome $user
    print "Your address is:$address";
</body>
</html>
Here's the error that I get The URL of the browser window is http://localhost/forms.php?user=tuxfan&address=Mumbai
Notice: Undefined variable: user in D:\apacheww\forms.php on line 4
Welcome
Notice: Undefined variable: address in D:\apacheww\forms.php on line 5
Your address is:
tuxfan is offline
Old 31-07-2005, 10:46 PM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Hi!
Try this:
<html><head></head>
<body>
  <?php
    $user=$_GET['user'];
    $address=$_GET['address'];
</body>
</html>
Hehe, if im not wrong, i was the one who got u started wid PHP (if u remember that is )
One suggestion: Go through the documentation at http://www.php.net You will find everything related to PHP there.
No book is better than that!
kalpik is offline
Old 31-07-2005, 10:53 PM   #3 (permalink)
kalpik's Avatar
Another solution. You dont need another html file for this!
<html><head></head>
<body>
  <?php
    $submit=$_GET['submit'];
    if(isset($submit))
    else
           </form>
           <?php
</body>
</html>
Havent tested it, maybe a typo here n there!
kalpik is offline
Old 01-08-2005, 04:18 PM   #4 (permalink)
tuxfan's Avatar
hey kalpik, thanks It worked. I would have PMed you if I wouldn't have got my answer in 24 hours I know you gave the last push required for me to get started on PHP.
I can understand what you are doing in the new forms.php file. The forum submission and processing is happenning in the same file depending on whether the submit button has called the page or its just loaded in the borwser through a link (or directly). Thanks for the tip
Actually, I have copied and pasted the code from an e-book. It gave errors. I checked another e-book, syntax looked right. I opened PHP manual, syntax still looked right :roll: So I was stumped. I even tried $_GET but it didn't work, may be I used $GET and missed out the underscore.
BTW, I am enjoying PHP
tuxfan is offline
Old 01-08-2005, 06:10 PM   #5 (permalink)
kalpik's Avatar
Sure anytime buddy! PHP really IS amazing.
Im actually doing training in TATA Infotech nowdays. Working on some JSP project, so got a chance to learn JSP too. But believe me JSP is NOTHING compared to PHP!
And u guessed right about what im doing in the new forms.php. I knew u were smart enough to figure that out urself, thats why didnt explain
And once again im saying that nothing beats the original PHP Manual from http://php.net. I've downloaded the many HTML files version. It is updated most frequently.
And if any other help required, ill be more than glad to help (if i can help that is!). Hehe...
Take care!
kalpik is offline
Old 01-08-2005, 07:11 PM   #6 (permalink)
sunnydiv
Posts: n/a
hey tuxfan u r using a crappy server
use apache with XAMPP ur first script works fine
Old 01-08-2005, 08:29 PM   #7 (permalink)
kalpik's Avatar
But that is not how the standards go! If u are learning something, learn it according to standards. Good programming practice is also an important thing.
And how dare u call Apache a crappy server!? Hehe its the most popular server on the internet!
kalpik is offline
Old 02-08-2005, 12:22 AM   #8 (permalink)
sunnydiv
Posts: n/a
m not calling apache the crappy one, even i use it, i am callin it a crappy package
Old 02-08-2005, 12:42 AM   #9 (permalink)
kalpik's Avatar
Oh! You talking about PHP+Apache+MySQL packages?
Well IMO, manual installation is the best, and i think Tuxfan did that only! Lol...
kalpik is offline
Old 02-08-2005, 12:43 PM   #10 (permalink)
tuxfan's Avatar
Yes kalpik you are right. I did manual installtion. I used (and have saved) that thread in Tutorials section where Deep posted the details and you fine tuned them. Thanks so much for your help.
I will surely get in touch with you as and when I am stuck. I now have a reliable source for all PHP difficulties. I will not lose that source so easily
sunnydiv, try out the manual installtion. Its not difficult at all!! Refer to that thread in Tutorials. Deep and kaplik have really made it easy. I did it in first shot!! So can you
I have always preferred some control over what I am doing and don't rely on automation too much. Nothing is ever automatic!! Someone has done it for you and therefore it looks automatic. Why not find out how he has done it?
Necessity is the mother of invention
Inquisitiveness is the mother of knowledge about that invention
tuxfan is offline
- by Krow
