Old 31-07-2005, 07:06 PM   #1 (permalink)
karthik55859's Avatar
Default how to compress a file?
hello everyone
How can i compress a file to minimum size using either a zip or rar i compressed it but only few KBs it compressed is their any settings we should make in winrar to still compress to smaller size,,,i have an 2.32 MB file i want it to b sent to floppy is their an any way to compress that file to 1.44 MB
karthik55859 is offline
Old 31-07-2005, 07:16 PM   #2 (permalink)
u can try 7zip . http://www.7-zip.org/
or ther is another format named as uha. just google it to get more info.
BlAsTeR is offline
Old 31-07-2005, 07:45 PM   #3 (permalink)
The amount of compression also depends on the file at hand.If you try a already compressed file you wont find much success.
But Imho UHARC is pretty good with compression.
The windows GUI frontend of uharc can be got from here :http://www.klaimsoft.com/winuha/
www.Oobertech.net
digen is offline
Old 31-07-2005, 07:48 PM   #4 (permalink)
try using split function ... using this u can compress or split bigger files into smaller ones or that fits in Floppy disks
Right click on the file / folder
select compress to zip file
then select volumes
specify the size or use predefined sizes
and then add them
there it goes .. u have 1.44 MB splits of a big one ..
u can again join them by opening any one file and extract it
Sites I Like most
[url]www.google.com[/url]
[url]www.thinkdigit.com[/url]
[url]www.indmall.com[/url]
azhaga is offline
Old 31-07-2005, 08:39 PM   #5 (permalink)
vignesh's Avatar
ZipGenius can compress in many formats.
vignesh is offline
Old 31-07-2005, 08:48 PM   #6 (permalink)
expertno.1's Avatar
if winrar cannot compress it in 1.44 mb then no any other compression utility will do
coz winrar has the best compression far better than zip
so you have use the split feature of winrar and disk spanning of winzip..whichever is good
also go for a dvd writer if you can afford
expertno.1 is offline
Old 31-07-2005, 10:07 PM   #7 (permalink)
q3_abhi's Avatar
Use Tformat (a very small utility) - formats ur floppy to 1.72 MB. Then use WinRAR's best compression n compress it.
Otherwise u will have to split those files.
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 31-07-2005, 10:35 PM   #8 (permalink)
Rebooting
Choto Cheeta's Avatar
well most of us use the compration tools to comprase data to smaller files to email them... now, if u have the same idia...then remember.... *.zip or *.rar & .cab r the most well know format... so if u use any absert format them email it... may b the recepaint dont have the tools to uncomprase it.... so use the format where u both have the uncompration tools....
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 02-08-2005, 07:02 PM   #9 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Most exes and other already optimized & compressed files can't be compressed much.. only those involving text.. like txt, doc, html... can be compressed to max...
The best of the lot'll be WinRAR, WinZip, UHARC...
ZipGenius is best for beginners... great userfriendliness... does everything and can open many many formats...
koolbluez is offline
Old 03-08-2005, 11:04 AM   #10 (permalink)
royal's Avatar
Compress in "Best" compression mode of WinRar
If this doesn't help split the files 8)
royal is offline
Old 03-08-2005, 11:09 AM   #11 (permalink)
Biplav's Avatar
well i will go with uharc.
that compressed my 1 gb game file to 266 mb
"Try again, fail again, fail better" - Samuel Beckett
Biplav is offline
Old 03-08-2005, 11:41 AM   #12 (permalink)
How did u do that?pls help me as i have to compress my games for uploading.
Mahesh Babu is offline
Old 03-08-2005, 12:01 PM   #13 (permalink)
Biplav's Avatar
i didnt do that
i posted it at a place and another techie did it for me.
well i will stll ask him out.
but he did rip off the music and movies too
Biplav is offline
Old 03-08-2005, 12:04 PM   #14 (permalink)
ya try for it
I want to rip a game including music.
Old 03-08-2005, 12:50 PM   #15 (permalink)
mekalodu
iinfi's Avatar
yummy !!! i will try it with my multimedia content !!!
thanks for the info
mekalodu
iinfi is offline
- by Krow
