Old 30-07-2005, 10:58 PM   #1 (permalink)
Maverick340's Avatar
Default Hiiden Partition
I want to create a virtual paswword protected small partition(*virtual)
.Mainly i want this partition to put in "imp" folders and files.
Miny aim is to keep it password protected..?
You and Me forever be ...
PSpwned
Maverick340 is offline
Old 31-07-2005, 01:57 AM   #2 (permalink)
String Phreak
mediator's Avatar
Well if ur using win98 it'll work but it wont!
Anyway its not some password trick! its a total restriction thing!
1. suppose u wanna secure "c:\temp" folder
2. goto command mode, enter root directory i.e c:\
3. type "ren temp alt+1234"->enter
Now see whether the temp folder has changed!
To bring it back to unsecure mode
type "ren alt+1234 temp"
here u can type any number instead 1234 and itwill give some symbol!
Caution!!!
If u forget the the symbol number like "1234" here, u may not be able to delete the folder by anymeans!
Rumours have it u maynot be even ableto format the disk!
mediator is offline
Old 31-07-2005, 02:00 AM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
In case if we forgot the symbol number, like 1234, we can safely rename or delete the folder in Win XP, cauz win xp lets u to view or edit the folder.
This trick doesnt work in XP only for 98...
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 31-07-2005, 02:07 AM   #4 (permalink)
Microsoft MVP
U can create ne partition and can make it invisible in my computer using following registry trick:
Start -> Run, type Regedit, goto:
HKey_Current_User\Software\Microsoft\Windows\Curre nt Version\Policies\Explorer
Now in right-pane create a new DWORD value NoViewOnDrive and set its value:
4: To protect C: Drive
8: To protect D: Drive
7: To protect A:, B:, C: Drive
3: To protect A:, B: Drive
f: To protect A:, B:, C:, D: Drive
3ffffff: To protect All Drive
0: To protect NO Drive
Old 31-07-2005, 07:39 AM   #5 (permalink)
expertno.1's Avatar
@vishal
dont post two times
expertno.1 is offline
Old 31-07-2005, 01:20 PM   #6 (permalink)
and how do i view it if i want to later on??
Thats y i wanted to create a partition thats hidden and password protected ,and can be unhidden and opend with the password whenever i want..
PSpwned
Old 31-07-2005, 01:23 PM   #7 (permalink)
Microsoft MVP
U can simply change the value of NoViewOnDrive to 0 in Registry, whenever u want to access the drive...
Old 31-07-2005, 01:59 PM   #8 (permalink)
Let the music play.....
djmykey's Avatar
What you can do is make a small partition and mount it on a folder and password protect it. See disk management in Win XP for further details. You can mount a partition on a folder just like in Linux.
djmykey is offline
- by Krow
