Old 30-07-2005, 01:42 PM   #1 (permalink)
bharat_r's Avatar
Default How to convert image into text
I have some images having text content.
Is there a way to convert them to editable text.
My scanner has some OCR thing which can convert scaned documents into editable text.
Not knowing this I scaned them to images.I don't have those papers now.
Is there any program to convert images to editable text?
Thanks
bharat_r is offline
Old 30-07-2005, 02:09 PM   #2 (permalink)
Default check this out
1. Get registered to this web page of National Library of Medicine, USA and submit ur file.
http://docmorph.nlm.nih.gov/docmorph/docmorph.htm
2. or take print of ur image file and scan again in word document format.
3. search google for 'screen ocr' software
godblessedson is offline
Old 31-07-2005, 02:14 AM   #3 (permalink)
bharat_r's Avatar
no.3 did the trick,
I didn't know what words I should put in the google search,
Thanks.
bharat_r is offline
Old 31-07-2005, 07:35 AM   #4 (permalink)
expertno.1's Avatar
get scanned the pics !
use snagit text capture
u r done
expertno.1 is offline
Old 31-07-2005, 08:22 AM   #5 (permalink)
you can use ABBYY Fine Reader 6.0 or 7.0 this helps you in getting the text in editable format
Live Life King Size
Mangal Pandey is offline
Old 31-07-2005, 09:20 AM   #6 (permalink)
expertno.1's Avatar
yes and this also
Screen Capture and ofcourse the software came from eith your scanner
- by Krow
