| Forum |
#1 (permalink) |
the reason this system will heat up because it is going to be used with software like maya and will be redering for hours and also i am a hard core gamer here is the config i am going to buy this week finaly amd 64 bit 3800 with venice core or 3700 with san diego core asus a8n sli delux mother board (has sound card and network card) xfx or asus 7800 gtx 4 x igb of trenscend or kingston ram 160 gb sata segate hard disk cdrw old rig dvd rom old rig 17 inch view sony moniter old rig a wacom garphic tablet will be atatched
EAT DRINK AND SLEEP 3D |
#2 (permalink) |
Your config doesnt deman any special config. So you could go in for any cabinet you like.I would recommend you, VIP ZB-01.
Where are you getting a 3800 Venice ? I mean have you confirmed ? also what is it costing you ? |
#3 (permalink) |
at lamington road 3700 with san diego is going to coat 21,500
and 3800 with venice core its 23,500 why are u so dought full is ther something u fell is not right becaus i had heard another dealer in borivili saying that 3800 venice is not yet come to indian market is it true
#4 (permalink) |
There are lot of 3800 Floating around but most are Winchesters i gues.
Also its not clearly mentioned on the CPU box whether it is a Venice or Winnie,you need to find out by the CPU Stepping...thats why i asked..As the dealers are completely unaware of the steppings and all that. 3700 is a guranteed SD as there was no 3700 in 939 before this. there was 3700 in s754 only if i remember correctly |
#5 (permalink) |
The Hardware Labs
man thats one hell of a rig ... for cabby i suggest d best "Antec Super Lan Boy" ...it is amazing and different... also get a minimum 400W smps from antec/coolermaster/powersafe if u dont want to screw up your rig.. go for 450W if u can , the more the better just to be safer. and hey dont forget a real good UPS for your rig. go for nothing less than APC (800 VA min.) .. and as for d procc like everyone had already suggested before go for 3700+ SD.
#7 (permalink) |
dark lord can u tell me what u mean by the word stepping is it the code something like bp for a venice on the chipset please explain
also mohit all ur suugestion have been note down i will go for antec mostly with 550 volts antec power supply and with 800 volts apc ups in antec i am confused which one a wirkstaion cabinate or lan boy pls tell which one and why
#8 (permalink) |
The Hardware Labs
Antec Super Lanboy is the best dude ... they use aluminium to make those cabinets....also u had mentioned u r a hardcore gamer , then definitely this one is for u , u get a carry in strap to carry the case with u to lan parties ... it just rocks man and it also comes fitted with two 120mm fans (front n rear) for cooling.. this is adequate i suppose. now its upto u to decide. and buy antec true power series power supply i.e true power 450W or higher. happy gaming :d
#9 (permalink) |
ya thanks for all the help i will surly go for it just one thing i wante dto ask how quiet it is can it retain the sound of the fans also as this my system will be on for hours to gather for redering do u suugest me put aextra fan or some colling system
#10 (permalink) |
The Hardware Labs
if u r going to work in an air-conditioned environment then i dont think u will require any further colling solutions for ur rig (unless u plan to overclock ur beast) ...the 2 fitted fans on the cabinet (front & rear) will provide adequate ventilation ... and the summer is a year away now , so dont worry !!!
and dont expect a pin drop silent cabinet , if u r going to work for long hours obviously the fans will rotate faster and create some noise atleast .. it will just be audible. u will have to adjust with that. relax. |
#12 (permalink) | |
Manchester United
Thanx
PS3-Ipod Touch 4G-Samsung Galaxy Ace-Sapphire HD 6870 Twin Frozer-Creative Zen
#13 (permalink) |
will you be able to run 4modules at ddr 400
also,don't take corsair value slect with asus nforce 4 why don't you take msi k8n diamond,does it have any probs with your card, why not take xms also, why 4gb ram?
Core i7 2600k|Gigabyte P67A UD4 B3|Corsair XMS3 2x4GB|HD6970|Coolermaster SilentPro 850M|Coolermaster HAF 932|Audioengine AE5|Samsung Galaxy S|Samsung Galaxy Tab 3G|Blackberry Curve 8520 |
#15 (permalink) |
Manchester United
Ok magnet, I have a GF 5200 128MB bought around a year back, cost me around 4500 bucks. I am planning to take a huge leap to a leadtek 6600GT 128MB, price qouted at around 11500 in Kolkata. I considered the x800 xl, but no distributor generally stocks it here. Have been saving for this for a long time. Finally will get it this month...Oh can't wait for the eye candy in Doom3 and HL2...and Farcry!!!
BTW, one off topic question, do you know when Civ4 will release in India?...
#16 (permalink) |
the msi board has a problem it cannot fit 2 7800 in a sli this is a companys tecnical mistake it performs great but if i am buyig a sli board then it should be a sli for me the card cost 33 thousand from xfx which is overclocked
magnet hum i want call myself rich no dought some people things sonn after they come out but my case is diff i am upgarding my computer after 6 years and that to because of a purpose i am buying this rig for 3d animation and i am buying 7800 because there will be sooon a sof mod out to convert it to a qudro 4500 since both have the same architect only diff driver consider this situation ia qudo 4500 cost 2 lakhs a 7800 cost 33 thousand now decide which u can afford
#17 (permalink) | ||
ADA3000DK4BI = Winchester ADA3000DAA4BP = Venice CBBID 0449 MPM = Winchester Stepping LBBLE 0517 EPAW = Venice Stepping Quote:
#18 (permalink) |
thank u very much dark lord i apprecaite ur help thank u and about lan boy yes these is one part which worrs me it is samll there is a asus cabinate i dont exactly rember its name its more like aalein ware cabinate but it is so big and i am sort of space in my room as this will be my second rig i will se if i can get another workstation model of antec h cabinate they should be big
#19 (permalink) | |
The Hardware Labs
![]() it is the asus vento chasis ... looks good and the specs r also good , http://www.asus.com/products4.aspx?l...79&modelmenu=1 but i dont think it is available in india. |
#21 (permalink) | |
The Hardware Labs
#22 (permalink) |
Who stole my Alpaca!
If Im correct, I heard or read somewhere ( Think it was on a different forum) that the Antect P180 cabinet as well as the Antec TruePower 2.0 series are now available in India. You could check those out.
http://www.antec.com/us/productDetails.php?ProdID=81800 http://www.antec.com/us/pro_p_truepw.html But Im pretty sure both together are going to cost an arm or a leg
The Ultimate Chess Strategy : "Hit Hard, Hit Fast and Hit Often" |
#24 (permalink) |
yup thats the beauty i am talking about i saw it at a shop in lamington road it cost 8 grands +500 it has no powersupply so u got to buy that too which makes it a expensive i have read its review in one of the sites syaing its a good cabinate but its pretty small and cramped funny huh it looks so huge but actually its just the casing outside whch makes it huge and bulky other wise its not that future proff upgradable cabinate so i think i will stick with antec the pi180 looks good even the landoy aslo its preety cheap looks quiet good any ways who lloks at the cabinate my eyes are glued on the moniter i will spend the cash on something like huh oh i will need to to think 3thousand is a lot of cash i will send u the siite were i read its review look at what the reviver felt ok this is the site u will have to find it was some where here
http://brnr.proboards36.com/index.cgi?board=Cases
#25 (permalink) |
The Asus Vento is also a good case. I posted the Antec one just to give you another option in case you liked it.
You could of course buy a regular case and just add a good smps and a couple of fans too it. Dont forget to check out the Iball cabinets I think they mgiht have a few good ones too which should be affordable
#26 (permalink) |
darky are u sure abt stepping doesn't winchester have dik in the middle sort of
also,how do you know that you will be able to covert 7800 to quadro 4500 are you take 7800gtx sli 256mb
#27 (permalink) |
well most of the bios flash are out soon afor conveting to qudro 6800 gt can easily be converted to a qudro yes ther are none out for 7800 right now but it wont be too long be fore one comes if not 4500 it still can be converted to a 4400 most of the architect of card are same only diffrance is in the drivers i trust soft modders more then nvida as simples as that
#28 (permalink) |
The Hardware Labs
Ibox cabinets suk BIIIIIIIIG TIME .. plase stay away frm them .. they are like "BAHAR SE SUNDAR , SADA HUA ANDAR" .... i found the antec p180 looking gr8 ... anybody know whats the price of the same ??
#29 (permalink) |
the super lanboy cost us 80 $ in india with tax its spld for 5000 to 5500
the p160 cost us 130 to 160 $ so india it would cost approximatly 8 to 10 k http://www.silentpcreview.com/article254-page1.html this is were i found the us price the indian price is a approximate it can be higher or lower
| Bookmarks |
| Display Modes | |
