Old 17-09-2004, 11:49 AM   #1 (permalink)
firewall's Avatar
Default How to restore GRUB
It's happened to almost every GNU/Linux and Windows dual boot user at some point: You have a nice installation GNU/Linux cross-booted with Windows. So far so good. But then, at some point, you reinstall Windows, perhaps because you upgraded to a new version, or perhaps you just did it to "clean up" Windows, reinstalling the original system files to make it a little more stable. When you reboot, however, you'll find that if you had LILO running from your hard disk's MBR, it has been killed, and Windows has claimed the MBR as its own. How will you reinstall your boot manager so you can get into GNU/Linux?
here is small tutorial on how to reinstall your gnu boot loader in that case. I chose GRUB here as now a days it's very popular and powerful too.
Boot into the rescue mode using install CD1 by typing "linux rescue" at the boot prompt. When it asks you if you want it to find your installation and mount it, let it by selecting "Continue". Once you get to the sh prompt chroot into you installation with:
# chroot /mnt/sysimage
If the disk you boot from is /dev/hda then you should be able to reinstall grub with:
# grub-install /dev/hda
Just remember to exit the chroot'ed shell before you reboot. If you reboot by "Ctrl-Alt-Del" the installer will unmount your partitions. Although it probably wouldn't hurt to try to unmount as many as you can yourself with something like:
# umount /dev/hd?[1-9]*
www.aloke.info
firewall is offline
Old 17-09-2004, 11:58 AM   #2 (permalink)
tuxfan's Avatar
Cool!! Some newbie has a thread here on the same problem. Why not post it there too!! Or shall I quote you there?
tuxfan is offline
Old 17-09-2004, 02:00 PM   #3 (permalink)
very cool!! I had the same problem once and because of the problem i did reinstall whole linux...
hope that won't happen again...
thouchin is offline
Old 17-09-2004, 02:41 PM   #4 (permalink)
firewall's Avatar
Oh ! i missed that....
btw just redirect that person to this thread.... simple...
www.aloke.info
firewall is offline
Old 17-09-2004, 02:53 PM   #5 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Thanx ...
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 18-09-2004, 12:23 AM   #6 (permalink)
Salieri Family
hard_rock's Avatar
Location: Somewhere in Internet.......Have dynamic IP address
I think Tuxfan, ur talkin abt me...........I have similar problem with grub loader..........Thanx 4 ur solution yaar.......
A person who wants everything in his life... May end up with nothing at all
-Tommy[Mafia]
hard_rock is offline
- by Krow
