Old 29-07-2005, 04:42 PM   #1 (permalink)
Default I can't use find
I have a windows XP Media Centered Edition. For the past few days me Find is not working. The only major change which I have done is unintalling MS Office.
From find I mean the windows find (Windows + F) or search as it is called in XP.
Please can any one tell me what is the problem.
Yathi is offline
Old 29-07-2005, 07:26 PM   #2 (permalink)
siriusb's Avatar
From this forum:
I had used Tweak-XP to 'Hide "Search"' (from the Classic Start Menu) Apparently, this also makes the Explorer Search button not to work.
Maybe you or someone else has done something similar (there's probably numerous programs for doing this kind of thing). You can also check/edit your registry yourself for this effect.
If you're comfortable with regedit use it and see if you can find the following entry:
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\Explorer\NoFind
If "NoFind" has the value "01 00 00 00" change it to "00 00 00 00" and it will probably solve your problem. You will need to restart ("log off & log in" will probably suffice).
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 30-07-2005, 01:56 PM   #3 (permalink)
I have also tried nofind but the key is not there in the registry. I have also tried in the local machine location. So do you or anyone else have any other suggestion?
Yathi is offline
Old 30-07-2005, 01:58 PM   #4 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Is <WIN>+F working?
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 30-07-2005, 02:01 PM   #5 (permalink)
Microsoft MVP
Copy-paste the following code in notepad and save it as <anyname>.reg:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\FindExtensions]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\FindExtensions\Static]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\FindExtensions\Static\ShellSearch]
@="{169A0691-8DF9-11d1-A1C4-00C04FD75D13}"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\FindExtensions\Static\ShellSearch\0]
@="For &Files or Folders..."
"LocalizedString"=hex(2):40,00,25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,\
  6f,00,6f,00,74,00,25,00,5c,00,73,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,\
  00,5c,00,53,00,48,00,45,00,4c,00,4c,00,33,00,32,00,2e,00,64,00,6c,00,6c,00,\
  2c,00,2d,00,32,00,33,00,32,00,33,00,32,00,00,00
"RunInProcess"="1"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\FindExtensions\Static\ShellSearch\0\DefaultIcon]
@=hex(2):25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,74,00,25,\
  00,5c,00,73,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,53,00,48,00,\
  45,00,4c,00,4c,00,33,00,32,00,2e,00,64,00,6c,00,6c,00,2c,00,2d,00,31,00,33,\
  00,34,00,00,00
"HotIcon"=hex(2):25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,\
  74,00,25,00,5c,00,73,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,53,\
  00,48,00,45,00,4c,00,4c,00,33,00,32,00,2e,00,64,00,6c,00,6c,00,2c,00,2d,00,\
  35,00,30,00,00,00
"GrayIcon"=hex(2):25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,\
  35,00,31,00,00,00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\FindExtensions\Static\ShellSearch\0\HelpText]
@="Search for files or folders"
  2c,00,2d,00,32,00,33,00,32,00,39,00,36,00,00,00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\FindExtensions\Static\ShellSearch\0\SearchGUID]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\FindExtensions\Static\ShellSearch\0\SearchGUID\UrlNavNew]
@=hex(2):3a,00,3a,00,7b,00,65,00,31,00,37,00,64,00,34,00,66,00,63,00,30,00,2d,\
  00,35,00,35,00,36,00,34,00,2d,00,31,00,31,00,64,00,31,00,2d,00,38,00,33,00,\
  66,00,32,00,2d,00,30,00,30,00,61,00,30,00,63,00,39,00,30,00,64,00,63,00,38,\
  00,34,00,39,00,7d,00,00,00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\FindExtensions\Static\ShellSearch\1]
@="For &Computers"
  2c,00,2d,00,32,00,33,00,32,00,33,00,33,00,00,00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\FindExtensions\Static\ShellSearch\1\DefaultIcon]
  00,35,00,00,00
  35,00,32,00,00,00
  35,00,33,00,00,00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\FindExtensions\Static\ShellSearch\1\HelpText]
@="Search for computers on the network"
  2c,00,2d,00,32,00,33,00,32,00,39,00,37,00,00,00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\FindExtensions\Static\ShellSearch\1\SearchGUID]
@="{996E1EB1-B524-11d1-9120-00A0C98BA67D}"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\FindExtensions\Static\ShellSearch\1\SearchGUID\UrlNavNew]
@=hex(2):3a,00,3a,00,7b,00,31,00,66,00,34,00,64,00,65,00,33,00,37,00,30,00,2d,\
  00,64,00,36,00,32,00,37,00,2d,00,31,00,31,00,64,00,31,00,2d,00,62,00,61,00,\
  34,00,66,00,2d,00,30,00,30,00,61,00,30,00,63,00,39,00,31,00,65,00,65,00,64,\
  00,62,00,61,00,7d,00,00,00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\FindExtensions\Static\ShellSearch\2]
@="For &Printer"
  2c,00,2d,00,32,00,33,00,32,00,33,00,34,00,00,00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\FindExtensions\Static\ShellSearch\2\DefaultIcon]
  00,35,00,00,00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\FindExtensions\Static\ShellSearch\2\HelpText]
@="Search for a printer"
  2c,00,2d,00,32,00,33,00,32,00,39,00,38,00,00,00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\FindExtensions\Static\ShellSearch\2\SearchGUID]
@="{D515F311-B78B-11d1-9123-00A0C98BA67D}"
Double-click on the file and then click on YES and then OK.
May be it can solve ur prob?
- by Krow
