Old 29-07-2005, 01:56 PM   #1 (permalink)
godsownman's Avatar
Default Getright troubles
I have recently installed getright 5.0 from my CD on to the computer to do a few downloads.
I have now noticed that getright consumes maximum bandwith of my dial up leaving little or no speed for me to work on the net.
As a result I have to choose whether I have to download or surf the net.
Is there anyway that I can equally divide the bandwith between the two so that I can surf as well as download in peace.
Thanks.
godsownman is offline
Old 29-07-2005, 02:59 PM   #2 (permalink)
Under Tools>Getright Configuration>Internet>Speed Limit
Define the appropriate speed limit you want depending on your requirement.Then make sure you check the "Obey the speed limit" box.
www.Oobertech.net
digen is offline
- by Krow
