Old 28-07-2005, 10:02 PM   #1 (permalink)
Default monitor out of Hz. can't rectify
My LG monitor is showing a message that monitor out of Hz. I have tried to log in the safe mode and from settings-monitor-refreshrate tried to change the refreshrate.But instead of giving any digit in the refreshrate drop down list its showing "Default hardware setting" message.Please tell how to change it.i use win2k prof.
ra_sriniketan is offline
Old 29-07-2005, 10:51 PM   #2 (permalink)
I'm back!
Default Try this...
Hi,
Go back to "Display Properties" > "Settings" Tab.
Set the "Scren Resolution" slider to "800 by 600 pixels".
Set the "Color Quality" to "Medium (16 Bit)" and then try changing the Refresh Rate.
If you can set the Refresh Rate now, set it to "75 Hertz" or lower. Apply all the changes and Restart.
If you can't change and still see "Default hardware setting" there, Apply the changes above and Close.
Now, open the "Display Properties" again and then try to set the Refresh Rate. If you still can't, Restart.
On Restart, check if you can boot normally. If you can, just boot normally.
If not, boot in "Safe Mode" and try to set the Refersh Rate again.
Once you set "Screen Resolution" to 800x600, "Color Quality" to 16 bit
and "Refresh rate" to 75 Hz or lower, you should be able to boot normally.
Once you do, simply change the settings to the values your system is comfortable with.
Ravi
Little Knowledge is Dangerous but a lot of Ignorance is just as Bad!
Minimalistix is offline
- by Krow
