View Poll Results: Which is better on price and performance?
Intel P4 1.8ghz 2 50.00%
Intel P4 2.0ghz 2 50.00%
Voters: 4. You may not vote on this poll
Old 02-04-2004, 11:25 PM   #1 (permalink)
Default Is it Feasible???
I am mentioning the prices for a new CPU.
Please help to decide on my behalf what is the
best solution for me to upgrade.My interests are
gaming,programming in Java,Oracle,C,C++ etc and
applications like Photoshop,illustrator,Fash,HTML.
i ALSO BURN CDS.
Config 1
Intel p4 2.0 Ghz
Intel 865gl motherboard chipset
128mb ddr ram (hyunDAI)
40GB HDD
cd WRITER
this one costing me around 15800 bucks
config 2
Intel p4 1.8 Ghz
40GB HDD
cd WRITER
this one costing me around 14800 bucks
config 3
Intel celeron 1.79Ghz
40GB HDD
cd WRITER
this one costing me around 13800 bucks
I am not considering any AMD solutions.
My second query is about motherboards.
Is there any difference between the original motherboard
and the chipset of same motherboard.Whcih one is better
and is more feasible to upgrade or buy to.
SIDBIT is offline
Old 03-04-2004, 12:02 AM   #2 (permalink)
another intel fan???
if ur looking to save those 1000precious bux go 4 the 1.8ghz, there aint no big difference btw the 2
Tifosi is offline
Old 03-04-2004, 12:57 AM   #3 (permalink)
Hi Sidbit
I would recommend you for AMD. You can get a better performing system for a similar price. But still if you wish to go in for an Intel system. I would recommend additional 128 MB RAM atleast and make sure it is DDR 400. In case you are going for a good motherboard like ASUS, Gigabyte, MSI then its OK if you go for the same chipset otherwise go in for the the Intel motherboard.
anupamsinha is offline
Old 03-04-2004, 12:57 AM   #4 (permalink)
Isn't an HT version of the 2.0 available?
He cud try that.
Definitely increase ur RAM to at least 256mb. U know that dell and gateway put 128mb standard on their comps way back in 98?
What do u mean by original mobo?
Gigabyte's mobos on the 865 chipset are just as original as the generic intel ones. Basically they might have a few extra features.
[/i]
kingkrool is offline
- by bhaskar
- by Deepaks
- by Anorion
