Old 26-07-2005, 09:15 PM   #1 (permalink)
Default integration of DAP 7.4 with opera 8.0browser
how to integrate dap 7.4 with opera 8.obrowser.i try to change the settings in preference window in dap.but it is not highlighted.pleaseeee helpppppppppppppppppp
ganga
ganga is offline
Old 26-07-2005, 11:55 PM   #2 (permalink)
hack expert's Avatar
i donno bout dap but i managed to get flashget working with opera 8.0
u get a plugin for flashget copy it into the opera\plugins direc.. and then change prefernces in opera maybe there`s a similar procedure for dap too
If electricty comes from electrons, does morality come from morons?
Flying is simple. You just throw yourself at the ground and miss
hack expert is offline
Old 27-07-2005, 10:02 AM   #3 (permalink)
Biplav's Avatar
dap cant be integrated with opera versions above 6.
so u need to go back in updates of the browser if u wanna continue with dap else do the manual way of downloading.
"Try again, fail again, fail better" - Samuel Beckett
Biplav is offline
Old 28-07-2005, 08:44 PM   #4 (permalink)
hcp006sl's Avatar
This is wrong. There is a technique to integrate opera 7.x with DAP 7.x. But, I am unable to use this method on Opera 8.x.
Orkut members are invited to join:
http://www.orkut.com/Community.aspx?cmm=28705185
hcp006sl is offline
Old 29-07-2005, 12:51 AM   #5 (permalink)
Biplav's Avatar
ok u might be rite. but i never tried with 7 .
so allow me to modify: dap cant be integrated with opera version above 7.
Biplav is offline
Old 30-07-2005, 10:21 PM   #6 (permalink)
Biplav's Avatar
well well well
indyan: ur trick worked.
thats gr8 news for me.
and yes to add to it:
try to add pdf, zip, rar and other extensions to dap too
but dont integrate rm and wmv files to dap as these are also used to stream video and music
Biplav is offline
Old 31-07-2005, 09:31 AM   #7 (permalink)
expertno.1's Avatar
now mine
1) copy the opera6.ini (opera/profile)file into operas main directory
2) rename it to opera.ini
3) use dap and integate..it wil work
4) now copy the opera.ini file back to the opera/profile direcotry and rename it to opera6.ini (remebr to delete the old one)
5) u r done
6) i am using dap 7.4 wiht this one now in opera
expertno.1 is offline
Old 31-07-2005, 12:07 PM   #8 (permalink)
hcp006sl's Avatar
But, the question is which version of opera do you use? Did you integrate DAP with Opera 7.x and then upgrade it to 8.x.
I told you that there is a technique to integrate Opera 7.x with DAP 7.x. And what is described by expertno1 is the technique to integrate Opera 7.x with DAP 7.x. So, download Opera 7.x without java or with java then integrate with DAP 7.x and then upgrade Opera to 8.x.
hcp006sl is offline
Old 31-07-2005, 10:33 PM   #9 (permalink)
Biplav's Avatar
hey guys do wat pally said and then even if u have dap watever versions and opera 8 then it still does the work. no need to install opera 7.x
Biplav is offline
Old 31-07-2005, 11:36 PM   #10 (permalink)
Gaurav's Avatar
I use Opera 8.02 and Flashget can be integrated with it.
Gaurav is offline
Old 28-08-2005, 11:20 PM   #11 (permalink)
Biplav's Avatar
integration od dap is actually very simple
in the connection tab just change the
USER AGENT to :
Mozilla/4.0 (compatible; MSIE 5.0; Windows 2000) Opera 7.0 [en]
as simple as that.
i am using opera 8.02 with dap 5.3
Biplav is offline
Old 01-09-2005, 09:04 PM   #12 (permalink)
expertno.1's Avatar
i use opera 8.02 with java and dap 7.4
Old 07-09-2005, 11:30 PM   #13 (permalink)
Ashis's Avatar
Hey Can any one Intgrate Download Express with Opera 8 ???
I consider Download Express as the best download manager due to its sear speed & no Fuss...No Nucence!
Ashis is offline
Old 08-09-2005, 06:07 PM   #14 (permalink)
expertno.1's Avatar
downlaod express gets automatically integrated into opera or else use
Old 09-09-2005, 03:47 PM   #15 (permalink)
y DAP ?
Try Internet Download Manager (claims 500% speed) only USD 24.95 while DAP premium USD 39.90 (400% Speed)
I use IDM, ( my browser Opera 7.54 with Java)it's so nice, interface is simple, performance much better than that of competitors,
integrate with IE, Opera, MOzilla, Netscape etc, clipboard funtions, customised download folders, no more resources required
IDM is simply the BEST.
Raaza is offline
Old 12-09-2005, 10:28 PM   #16 (permalink)
Download Studio too integrates with any browser.
A bit faster than DAP if it is tweaked.
Yesterday - Dead
Today - Dying
Tomorrow - Never dies
The day after tomorrow - Where will you be !
Sreekanth V is offline
Old 13-09-2005, 09:51 PM   #17 (permalink)
expertno.1's Avatar
y DAP ?
Hi Raaza,
I am sorry to say but you are diverting from the topic
we are not here do discuss which is better ot which is bad
the question is "how to integrate dap 7.4 with opera 8.obrowser"
and we should be in this line only
ok ganga ,
did my solution worked ?
please post
@Raaza u can aslo see this thread for which DM to choose from
http://www.thinkdigit.com/forum/viewtopic.php?t=19326
thanks
Regards...
Expertno.1
Old 14-09-2005, 03:32 PM   #18 (permalink)
Ashis's Avatar
what indyan said
Hey...It doesnt happen In My case!
I have tried what Indyan said & the DE starts but the URL is not passed to it
Even if I have checked the option to pass URL !
Let me download a new version & then try (Download Express)
Ashis is offline
Old 14-09-2005, 06:04 PM   #19 (permalink)
really my intention is not divert
anyway sorry for that
Raaza is offline
Old 17-09-2005, 02:58 AM   #20 (permalink)
Ashis's Avatar
Originally Posted by Indyan
Wht is the difference between download express and mass downloader?DE says it is powered by Mass Downloader.
mass downloader integrates perfectly with opera.
I dont Know the Difference nor I am interested....All i know is I like Download Express more than Mass Downloader....& now i want It to Integrate with Opera like, as U said Mass Downloader does! :roll:
..............Can u Help Me ???
Did Download Express Integrates with opera in Ur system ???
Ashis is offline
- by Krow
