The board will be available soon enough here in Hyd and visit the below link for its features.
http://www.msicomputer.com/product/p...0M-IL&class=mb
*Dual core ready
CPU
• Supports 64-bit AMD® Athlon64 processor (Socket 754)
• Supports 2800+, 3000+, 3200+, 3400+, 3700+
• Supports Sempron 2600+, 2800+, 3000+, 3100+, 3300+
Chipset
• ATI Radeon® XPRESS 200 Chipset
- HyperTransport connection to AMD K8 Athlon 64 processor
- 8 or 16 bit control/address. data transfer both directions
- 800/400/200MHz "Double Data Rate" operation both direction
- PCI Express x16 Graphic Interface
- On-board Graphic shared up to 128MB
- Graphic Integrated
• ATI ® SB400 Chipset
- Supports dual channel native Serial ATA/RAID controller that will supply 150MB/s and support RAID 0 or RAID 1
- Integrated Hardware Sound Blaster / Direct Sound AC97 audio
- ACPI & PC2001 compliant enhanced power management
- Supports 8 USB2.0 ports (Rear x 4 / Front x 4)
Main Memory
• Supports two 184-pin DDR SDRAMs up to 2GB memory size
Supports Dual Channel DDR400*/DDR333 DDR SDRAM
Slots
• One PCI Express 16X slot
• Three PCI 32-bit Master PCI Bus slots. (support 3.3v / 5v PCI bus interface)
