Old 26-07-2005, 01:21 PM   #1 (permalink)
Default .xdr files
the other i was just roaming abt in the C: drive , & in my search i found many windows files with the extension .xdr
Wat does this extension mean?
Wat do these files do?
Think about it!
Trinity is offline
Old 26-07-2005, 01:27 PM   #2 (permalink)
MVP in VC++
.Xdr files are -
Like XML-Data, XDR is a syntax for Extensible Markup Language (XML) schemas that define the characteristics of an XML document. XDR is a subset of XML-Data. You can create an XSD schema from an XDR schema with a conversion script.
cvvikram is offline
Old 26-07-2005, 01:30 PM   #3 (permalink)
alib_i's Avatar
next time you need know about an extension ..
use www.filext.com
An XML Schema dialect proposed by Microsoft and submitted to the World Wide Web Consortium (W3C) in 1998. Like XML-Data, XDR is a syntax for Extensible Markup Language (XML) schemas that define the characteristics of an XML document. XDR is a subset of XML-Data. You can create an XSD schema from an XDR schema with a conversion script.
from same site
alibi
-Metallica
alib_i is offline
Old 08-08-2005, 08:42 AM   #4 (permalink)
hey thanx buddy www.filext.com is indeed very useful & replies to many of my queries.
Thanx a bunch!
Think about it!
Trinity is offline
Old 08-08-2005, 04:44 PM   #5 (permalink)
expertno.1's Avatar
filext.com is my first site for which i look for extension softwraes and then post here
expertno.1 is offline
